#1 2019-03-26 13:56
Centaurus 3.5 r4 Konsole font issue
In r4 Centaurus, when you open konsole the $ prompt is partially over the n in debian.
If you then type anything the cursor seems to be stepped one space to the right all the time.
Swapping the font from deja-vu sans to a mono font clears the issue
#2 2019-03-26 17:54
Re: Centaurus 3.5 r4 Konsole font issue
We are not able to reproduce that, the default Konsole font looks right in KDE as well as TDE. Do you notice the issue within the live media ? Anyone else can confirm this issue ?
#3 2019-03-26 20:50
jotapesse
No issues here on Virtualbox.
#4 2019-03-27 07:44
I've gone back over how I get there and it looks like it is triggered when setting anti-aliasing. I normally run with RGB Slight.
Attached screenshots show with default font after using View>Enlarge Font to make it easier to see.  It is the same at default size.
The gap after the text just happens - as soon as the next key is pressed the letter is in the right place, but the gap after is still there. Can be disconcerting.
