Hei boys!!! downloding q4os-2.7-x64.r2 Not run! Use rufus (message need syslinux 6.03)
Ok my penusb working,boot my old MacBook early 2008!
Is very very fast,try to install,language my keybord layout not working
You help me install layout keyboard?
So sorry my bad talk iam not English
Hi, at least your English is as bad as my one :-)
As far as I could understand your problem is only relevant the keyboard layout.
When I installed another debian distro on a Macbook pro 2008, the needs where the following:
1. MUST have a 64 bit version,
2. should have a CD/DVD media to install (but I see that you didnt have this problem)
3. install an utility called macfan (or something like that) otherwise you may have hesting probs: THIS IS IMPORTANT
4. dont use teh proposed keyboard Mac layout, instead you should choose the 1st proposal of the list (with me it worked very well with the Italian)
5. in order to make the wifi working you should install the b43 drivers
6. I also preferred to install the Nvidia drivers, in order to see movies on the Mac
I hope the above tips may help you
