#1 2019-02-01 09:07
Italopit
installing a printer
Hello Forum, I'm new and a absolute beginner. First, i think that the Q4OS is an absolute beauty and i would like to install it. In this moment i'm using Zorin OS.
I prooved to install it on an Macbook Air (end 2010) and it was absolute functionally. The only problem is the printer. There was never an option or menu to install a driver. It simply doesn't exist and i tryed a lot to find it. I thougt that it was a problem of the mac and made another installation on a PC with the same result. I can't find the installation option. Can anyone help me, thank you, Peter
#2 2019-02-01 09:30
Re: installing a printer
Have you checked the documentation?
#3 2019-02-01 09:54
Italopit
Yes but in "settings" is no option to add a printer.
#4 2019-02-01 10:33
Italopit
problem solved - the graphics for the printer installation weren't installed. Now it's all ok - i found in synaptic packages . :-)
#5 2019-02-01 12:29
@Italopit
What packages did you need to install ? Thanks for reporting.
