#1 2019-01-24 20:29
antares
thumbnails
Installed and discovered that there are no icons on videos
Added Thunar but no avail as well
Plz help
#2 2019-01-24 20:42
Re: thumbnails
Have you enabled previews? From konqueror (file manager) menu View -> Preview -> Enable Previews You will need to be in Icon view to see thumbnails.
#3 2019-01-24 21:58
antares
Re: thumbnails
Yes;........;;;still no icons
And thunar has no imagees at all.........;;just empty spaces............;but with titles
#4 2019-01-24 22:13
Re: thumbnails
You could try using tumbler, I used to use it with Debian Xfce some time ago but have not tried it recently, I can't remember exact instructions for it but after installation you could type man tumbler to get an idea of any configuration you might need to do.
#5 2019-01-24 22:17
JimW
Re: thumbnails
I have never gotten previews in konquorer. All I get is the film strip icon. This is with previews checked or unchecked.
I think I said something about this long ago and (if I remember correctly) was told it was something debian did.
#6 2019-01-24 22:31
antares
Re: thumbnails
tumbler is installed
#7 2019-01-24 22:35
antares
Re: thumbnails
most of distros have no such a problem and no need to activate anything
but this one has................;;;
#8 2019-01-24 23:40
Re: thumbnails
Trinity desktop and Konqueror file manager cannot display thumbnails, or previews, on video files icons. This feature is not implemented in Trinity.
We can confirm a bug in Thunar, it doesn't recognize Crystalsvg icons at all. We will check and possibly report that at appropriate upstream developers.
We recommend you to use the Plasma desktop, as it's the default desktop for Q4OS. You could always switch into the Trinity desktop as a fast and lightweight, however not so advanced, alternative.
EDIT: You can get thumbnails and previews on video files icons in Konqueror, once you install the "libarts1-xine-trinity" package:
$ sudo apt install libarts1-xine-trinity
#9 2019-01-25 02:00
JimW
Re: thumbnails
Hey! That did it! Got my video previews back!
Thanks again Q4OSteam!
#10 2019-01-25 02:01
Jaerrib
Re: thumbnails
Somewhat off topic... Is Trinity still being considered the primary desktop for Q4OS or has Plasma taken that title?
#11 2019-01-25 07:58
antares
Re: thumbnails
SOLVED !
This is just what was needed !
but thunar is still with empty spaces.........................to be uninstalled...........
and another question
how to change colours of folders in konqueror?
#12 2019-01-25 08:45
Re: thumbnails
The first option would be to set another icon set. If it's not what you want, you could try to configure colorization of Crystalsvg icons by setting icons effects.
First unlock advanced configuration options:
sudo kcmodules --unlock
Run Control panel > Appearance & themes > Icons > Advanced tab > set colorization effects for different icon types.
@Jaerrib
One of the Q4OS specific goals is the ability to have Plasma and Trinity desktop alongside each other installed. Users can switch back and forth between Plasma and Trinity. Both desktops can independently coexist side by side and don't interfere with each other. The key is that Trinity is an integral part of Q4OS, so any Q4OS installation, even with Plasma, bears Trinity desktop. In other words, you can have Q4OS without Plasma, but you can't without Trinity. Plasma is being the logical primary choice for most of users, so it's considered to be the default option, which is also obvious from the Q4OS downloads site.
#13 2019-01-25 08:57
Re: thumbnails
We have considered to include the "libarts1-xine-trinity" package into the Full profile for the Desktop profiler tool. It will be released in a next Q4OS release. Thanks for reporting.
