System: Host: q4os-desktop Kernel: 4.9.0-8-686-pae i686 (32 bit)
Desktop: KDE Plasma 3 Distro: Debian GNU/Linux 9 (stretch)
Machine: Device: desktop System: Hewlett-Packard product: hp t5740
Mobo: Hewlett-Packard model: 3641h
BIOS: American Megatrends v: 786R8 v1.04 date: 03/22/2011
CPU: Single core Intel Atom N280 (-HT-) cache: 512 KB
clock speeds: max: 1667 MHz 1: 1333 MHz 2: 1333 MHz
Graphics: Card: Intel Mobile 4 Series Integrated Graphics Controller
Resolution: 1360x768@60.02hz
GLX Renderer: Mesa DRI Mobile Intel GM45 Express x86/MMX/SSE2
GLX Version: 2.1 Mesa 13.0.6
Audio: Card Intel 82801I (ICH9 Family) HD Audio Controller
driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.9.0-8-686-pae
Network: Card-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter
driver: rtl8192ce
IF: wlp3s0 state: up mac: 68:a3:c4:84:7b:4c
Card-2: Broadcom Limited NetLink BCM57780 Gigabit Ethernet PCIe
driver: tg3
IF: enp4s0 state: down mac: 18:a9:05:6b:d0:7f
Drives: HDD Total Size: 322.1GB (3.3% used)
ID-1: /dev/sda model: 2GB_ATA_Flash_Di size: 2.0GB
ID-2: USB /dev/sdb model: 3AS size: 320.1GB
Partition: ID-1: / size: 285G used: 2.6G (1%) fs: ext4 dev: /dev/sdb2
ID-2: /boot size: 1.4G used: 38M (3%) fs: ext4 dev: /dev/sda1
ID-3: swap-1 size: 8.10GB used: 0.00GB (0%) fs: swap dev: /dev/sdb1
Sensors: System Temperatures: cpu: 18.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 129 Uptime: 7 min Memory: 303.5/2967.9MB
Have you tried the documentation?
Our timing is getting terrible ![]()
Yes, we have removed our post, as that was the same ![]()
Yes, I tried all that...nothing...
What output did you get from any of the commands you used?
brian@q4os-desktop:~/Desktop$ sudo apt install pulseaudio pavucontrol-qt
Reading package lists... Done
Building dependency tree
pavucontrol-qt is already the newest version (0.2.0-1).
pulseaudio is already the newest version (10.0-1+deb9u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
brian@q4os-desktop:~/Desktop$ artsplay /opt/trinity/share/sounds/KDE_Startup.wav
no sound
brian@q4os-desktop:~/Desktop$ artsshell terminate
sound server terminated
brian@q4os-desktop:~/Desktop$ aplay /opt/trinity/share/sounds/KDE_Startup.wav
bash: aplay: command not found
no sound
brian@q4os-desktop:~/Desktop$ artsd -l 0
artsd version is 1.5.10
[artsd: 24121] SoundServerStartup --> got lock
autodetecting driver:
- oss: 10
- alsa: 15
- null: -1
- toss: 4
... which means we'll default to alsa
ALSA driver: default
buffering: 7 fragments with 1024 bytes (audio latency is 40.6 ms)
Closing ALSA-driver
virtualize StereoVolumeControl
audio format is 44100 Hz, 16 bits, 2 channels
addDirectory(/opt/trinity/lib/mcop,)
addDirectory(/opt/trinity/lib/mcop/Arts,Arts)
addDirectory(/home/brian/.mcop/trader-cache,)
[artsd: 24121] SoundServerStartup <-- released lock
xrun!!
still nothing
ran sudo lspci -v
and got this
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
Subsystem: Intel Corporation Optiplex 755
Flags: bus master, fast devsel, latency 0, IRQ 27
Memory at fe9f8000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [130] Root Complex Link
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
grabbed a .wav file from internet, and got this....
brian@q4os-desktop:~/Downloads$ ls
griffin-01.wav
brian@q4os-desktop:~/Downloads$ aplay -v griffin-01.wav
You need to install "alsa-utils" package.
$ sudo apt install alsa-utils
Try to run "aplay" commands again and post the result.
Playing WAVE 'griffin-01.wav' : Unsigned 8 bit, Rate 44100 Hz, Mono
ALSA <-> PulseAudio PCM I/O Plugin
Its setup is:
stream : PLAYBACK
access : RW_INTERLEAVED
format : U8
subformat : STD
channels : 1
rate : 44100
exact rate : 44100 (44100/1)
msbits : 8
buffer_size : 22050
period_size : 5512
period_time : 125000
tstamp_mode : NONE
tstamp_type : GETTIMEOFDAY
period_step : 1
avail_min : 5512
period_event : 0
start_threshold : 22050
stop_threshold : 22050
silence_threshold: 0
silence_size : 0
boundary : 1445068800
After a reboot, it is now working, thank you. Can you elaborate about the reinstallation of the ALSA Utils getting this to work? I like to understand a fix as much as possible.
If you install Q4OS from the installation CD and apply no profile in the Desktop Profiler, the system stays at the most basic and clean state. This install method is recommended for highly experienced users only. You should apply at least the basic profile, the "alsa-utils" package will be installed within the profile.
Thank you so much, was rather in a hurry the day I installed it on this pc, and didn't realize I had done this...thanks for clarifying what I had done in error.
I was curious as to what had caused this...I actually used Q4OS to install Linux on an OLD --HP st5740--that supposed to be a thin client only. but after using the IDE ssd as a boot partition only, and shoe-horning a 2.5 inch hdd inside it for the root, and all the rest it works just like a very tiny, portable pc that I got online for $15 that I use for online stuff in hotel rooms when I travel now...so If Q4OS willl get THAT to work this OLD pc should work just fine too...thanks again.
