Hello!
So, yes, I was tinkering with Q4OS and screwed up. And now I boot into 'Debian tty1, user login: .....' This is what happened:
I installed LXDE from 'profile manager'. Then uninstalled it via Synaptic, updated my system via terminal, and used autoremove when prompted. That was mistake. And now I don't have display manager. What should I do to be normal again?
Thank you!
You need to run in terminal:
$ sudo dpkg-reconfigure tdm-trinity
and set "Tdm" as the default DM
That helped.
Thanks a lot!
