#1 2019-01-03 21:15
danielson
Grub-customizer for Scorpion? [Solved]
Much to my surprise, i found Grub-customizer on Centaurus but not for Scorpion.
Searching through the forum here, none of the options work for Scorpion.
Is there a more recent file on Q4OS that i missed?
DELL Optiplex 7060 - 8G RAM.
#2 2019-01-03 21:39
Re: Grub-customizer for Scorpion? [Solved]
Have you checked the q4os experimental repository I haven't tried it recently but I think the grub-customizer installer should work on Scorpion
#3 2019-01-03 22:43
danielson
Yes, have tried.
But thanks!
#4 2019-01-04 00:12
grub-customizer should be available from the "stretch-backports" repository, see https://backports.debian.org/
#5 2019-01-04 02:23
danielson
Okay. Something new for me to discover. Thanks!
#6 2019-01-04 15:26
By the way, the most easy way to add backports repository is to use Q4OS dedicated tools, please see the documentation https://www.q4os.org/dqa007.html#extrepo
#7 2019-01-08 12:24
danielson
Before i completely forget to write in to say thank you.
It works! wink
