#1 2016-01-26 02:05
q4os_user
USB SATA adapter doesn't work
When I'm trying to connect my HDD or CD-ROM drive through SATA adapter to a USB port it doesn't work. On Kubuntu 8.04 and Windows Vista everything's OK. What can I do to fix this?
#2 2016-01-26 08:35
Re: USB SATA adapter doesn't work
Probably Q4OS/Debian kernel doesn't include needed drivers for the adapter. Try to connect the adapter and run in terminal:
$ lsusb
$ dmesg
and put output here to analyze.
Alternatively you could use Q4OS 2.0.2 Scorpion live CD http://www.q4os.org/downloads2.html , and check if adapter is recognized.
#3 2016-01-26 14:37
MC
I can confirm this happens on my system as well. External HDD not mounting / not present in file manager.
mc@q4os-desktop:~$ lsusb
Bus 001 Device 002: ID 05e3:0718 Genesys Logic, Inc. IDE/SATA Adapter
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
mc@q4os-desktop:~$ dmesg
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.3.0-0.bpo.1-amd64 (debian-kernel@lists.debian.org) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP Debian 4.3.3-7~bpo8+1 (2016-01-19)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.3.0-0.bpo.1-amd64 root=UUID=2140ee23-26dc-43f9-86b9-5c6c90c2fac5 ro quiet loglevel=3 TERM=dumb
[    0.000000] tseg: 00b7f00000
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] x86/fpu: Using 'lazy' FPU context switches.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f3ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f400-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000b7edffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000b7ee0000-0x00000000b7ee2fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000b7ee3000-0x00000000b7eeffff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000b7ef0000-0x00000000b7efffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000b8000000-0x00000000bfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f3ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000ffffffff] reserved
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.5 present.
[    0.000000] DMI: BIOSTAR Group N61PB-M2S/N61PB-M2S, BIOS 6.00 PG 09/03/2009
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] AGP: No AGP bridge found
[    0.000000] e820: last_pfn = 0xb7ee0 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-C7FFF write-protect
[    0.000000]   C8000-FFFFF uncachable
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000000 mask FFFF80000000 write-back
[    0.000000]   1 base 000080000000 mask FFFFC0000000 write-back
[    0.000000]   2 disabled
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] found SMP MP-table at [mem 0x000f3a30-0x000f3a3f] mapped at [ffff8800000f3a30]
[    0.000000] Base memory trampoline at [ffff880000099000] 99000 size 24576
[    0.000000] Using GB pages for direct mapping
[    0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[    0.000000]  [mem 0x00000000-0x000fffff] page 4k
[    0.000000] BRK [0x01d39000, 0x01d39fff] PGTABLE
[    0.000000] BRK [0x01d3a000, 0x01d3afff] PGTABLE
[    0.000000] BRK [0x01d3b000, 0x01d3bfff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0xb7c00000-0xb7dfffff]
[    0.000000]  [mem 0xb7c00000-0xb7dfffff] page 2M
[    0.000000] BRK [0x01d3c000, 0x01d3cfff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0xa0000000-0xb7bfffff]
[    0.000000]  [mem 0xa0000000-0xb7bfffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x80000000-0x9fffffff]
[    0.000000]  [mem 0x80000000-0x9fffffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x00100000-0x7fffffff]
[    0.000000]  [mem 0x00100000-0x001fffff] page 4k
[    0.000000]  [mem 0x00200000-0x3fffffff] page 2M
[    0.000000]  [mem 0x40000000-0x7fffffff] page 1G
[    0.000000] init_memory_mapping: [mem 0xb7e00000-0xb7edffff]
[    0.000000]  [mem 0xb7e00000-0xb7edffff] page 4k
[    0.000000] BRK [0x01d3d000, 0x01d3dfff] PGTABLE
[    0.000000] RAMDISK: [mem 0x35764000-0x36ba9fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000F7E60 000014 (v00 Nvidia)
[    0.000000] ACPI: RSDT 0x00000000B7EE3000 000038 (v01 Nvidia NVDAACPI 42302E31 NVDA 00000000)
[    0.000000] ACPI: FACP 0x00000000B7EE3080 000074 (v01 Nvidia NVDAACPI 42302E31 NVDA 00000000)
[    0.000000] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20150818/tbfadt-654)
[    0.000000] ACPI: DSDT 0x00000000B7EE3100 005B85 (v01 NVIDIA NVDAACPI 00001000 MSFT 03000000)
[    0.000000] ACPI: FACS 0x00000000B7EE0000 000040
[    0.000000] ACPI: SSDT 0x00000000B7EE8D80 0008F5 (v01 PTLTD  POWERNOW 00000001  LTP 00000001)
[    0.000000] ACPI: HPET 0x00000000B7EE9680 000038 (v01 Nvidia NVDAACPI 42302E31 NVDA 00000098)
[    0.000000] ACPI: MCFG 0x00000000B7EE96C0 00003C (v01 Nvidia NVDAACPI 42302E31 NVDA 00000000)
[    0.000000] ACPI: APIC 0x00000000B7EE8CC0 000098 (v01 Nvidia NVDAACPI 42302E31 NVDA 00000000)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] Scanning NUMA topology in Northbridge 24
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x00000000b7edffff]
[    0.000000] NODE_DATA(0) allocated [mem 0xb7edc000-0xb7edffff]
[    0.000000]  [ffffea0000000000-ffffea0002dfffff] PMD -> [ffff8800b4800000-ffff8800b75fffff] on node 0
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000b7edffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000b7edffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x00000000b7edffff]
[    0.000000] On node 0 totalpages: 753278
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 11708 pages used for memmap
[    0.000000]   DMA32 zone: 749280 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x1008
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 4, version 17, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] ACPI: IRQ14 used by override.
[    0.000000] ACPI: IRQ15 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x10de8201 base: 0xfeff0000
[    0.000000] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000effff]
[    0.000000] PM: Registered nosave memory: [mem 0x000f0000-0x000fffff]
[    0.000000] e820: [mem 0xc0000000-0xefffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] PERCPU: Embedded 32 pages/cpu @ffff8800b7c00000 s94168 r8192 d28712 u524288
[    0.000000] pcpu-alloc: s94168 r8192 d28712 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 741485
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.3.0-0.bpo.1-amd64 root=UUID=2140ee23-26dc-43f9-86b9-5c6c90c2fac5 ro quiet loglevel=3 TERM=dumb
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] AGP: Checking aperture...
[    0.000000] AGP: Node 0: aperture [bus addr 0x421e000000-0x421fffffff] (32MB)
[    0.000000] Aperture beyond 4GB. Ignoring.
[    0.000000] Memory: 2930820K/3013112K available (5693K kernel code, 1119K rwdata, 2812K rodata, 1304K init, 844K bss, 82292K reserved, 0K cma-reserved)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:33024 nr_irqs:456 16
[    0.000000] spurious 8259A interrupt: IRQ7.
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 3013.653 MHz processor
[    0.000028] Calibrating delay loop (skipped), value calculated using timer frequency.. 6027.30 BogoMIPS (lpj=12054612)
[    0.000031] pid_max: default: 32768 minimum: 301
[    0.000039] ACPI: Core revision 20150818
[    0.003898] ACPI: 2 ACPI AML tables successfully acquired and loaded
[    0.003925] Security Framework initialized
[    0.003928] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.003934] AppArmor: AppArmor disabled by boot time parameter
[    0.004201] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.005831] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.006612] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.006618] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.006897] Initializing cgroup subsys io
[    0.006904] Initializing cgroup subsys memory
[    0.006909] Initializing cgroup subsys devices
[    0.006912] Initializing cgroup subsys freezer
[    0.006915] Initializing cgroup subsys net_cls
[    0.006919] Initializing cgroup subsys perf_event
[    0.006922] Initializing cgroup subsys net_prio
[    0.006943] CPU: Physical Processor ID: 0
[    0.006944] CPU: Processor Core ID: 0
[    0.006946] mce: CPU supports 6 MCE banks
[    0.006953] LVT offset 0 assigned for vector 0xf9
[    0.006956] process: using AMD E400 aware idle routine
[    0.006958] Last level iTLB entries: 4KB 512, 2MB 16, 4MB 8
[    0.006959] Last level dTLB entries: 4KB 512, 2MB 128, 4MB 64, 1GB 0
[    0.007175] Freeing SMP alternatives memory: 20K (ffffffff81c5f000 - ffffffff81c64000)
[    0.009012] ftrace: allocating 23700 entries in 93 pages
[    0.016037] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.161483] smpboot: CPU0: AMD Athlon(tm) II X2 250 Processor (family: 0x10, model: 0x6, stepping: 0x3)
[    0.161510] Performance Events: AMD PMU driver.
[    0.161514] ... version:                0
[    0.161515] ... bit width:              48
[    0.161516] ... generic registers:      4
[    0.161516] ... value mask:             0000ffffffffffff
[    0.161517] ... max period:             00007fffffffffff
[    0.161518] ... fixed-purpose events:   0
[    0.161519] ... event mask:             000000000000000f
[    0.161976] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.162063] x86: Booting SMP configuration:
[    0.162065] .... node  #0, CPUs:      #1
[    0.175054] x86: Booted up 1 node, 2 CPUs
[    0.175056] smpboot: Total of 2 processors activated (12054.61 BogoMIPS)
[    0.175663] devtmpfs: initialized
[    0.178989] PM: Registering ACPI NVS region [mem 0xb7ee0000-0xb7ee2fff] (12288 bytes)
[    0.179052] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.179116] pinctrl core: initialized pinctrl subsystem
[    0.179241] NET: Registered protocol family 16
[    0.189538] cpuidle: using governor ladder
[    0.201547] cpuidle: using governor menu
[    0.201565] node 0 link 0: io port [8000, ffff]
[    0.201567] TOM: 00000000c0000000 aka 3072M
[    0.201569] Fam 10h mmconf [mem 0xf0000000-0xf00fffff]
[    0.201571] node 0 link 0: mmio [a0000, bffff]
[    0.201573] node 0 link 0: mmio [c0000000, efffffff]
[    0.201575] node 0 link 0: mmio [f4000000, fe02ffff]
[    0.201577] node 0 link 0: mmio [f0000000, f03fffff] ==> [f0100000, f03fffff]
[    0.201579] bus: [bus 00-04] on node 0 link 0
[    0.201580] bus: 00 [io  0x0000-0xffff]
[    0.201582] bus: 00 [mem 0x000a0000-0x000bffff]
[    0.201583] bus: 00 [mem 0xc0000000-0xefffffff]
[    0.201584] bus: 00 [mem 0xf0400000-0xfcffffffff]
[    0.201585] bus: 00 [mem 0xf0100000-0xf03fffff]
[    0.201668] ACPI: bus type PCI registered
[    0.201670] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.201757] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000)
[    0.201759] PCI: MMCONFIG at [mem 0xf0000000-0xf3ffffff] reserved in E820
[    0.201768] PCI: Using configuration type 1 for base access
[    0.214005] ACPI: Added _OSI(Module Device)
[    0.214008] ACPI: Added _OSI(Processor Device)
[    0.214009] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.214011] ACPI: Added _OSI(Processor Aggregator Device)
[    0.217210] ACPI: Interpreter enabled
[    0.217219] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20150818/hwxface-580)
[    0.217223] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S3_] (20150818/hwxface-580)
[    0.217231] ACPI: (supports S0 S1 S4 S5)
[    0.217232] ACPI: Using IOAPIC for interrupt routing
[    0.217254] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.222648] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-04])
[    0.222654] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.222775] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PCIeCapability]
[    0.222834] acpi PNP0A08:00: _OSC: not requesting control; platform does not support [PCIeCapability]
[    0.222836] acpi PNP0A08:00: _OSC: OS requested [PCIeHotplug PME AER PCIeCapability]
[    0.222838] acpi PNP0A08:00: _OSC: platform willing to grant [PME AER]
[    0.222839] acpi PNP0A08:00: _OSC failed (AE_SUPPORT); disabling ASPM
[    0.223494] PCI host bridge to bus 0000:00
[    0.223497] pci_bus 0000:00: root bus resource [bus 00-04]
[    0.223499] pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
[    0.223501] pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
[    0.223502] pci_bus 0000:00: root bus resource [io  0x8000-0xffff window]
[    0.223504] pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
[    0.223505] pci_bus 0000:00: root bus resource [io  0x1c00-0x1c80 window]
[    0.223507] pci_bus 0000:00: root bus resource [mem 0xfec80000-0xfecbffff window]
[    0.223509] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.223510] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xefffffff window]
[    0.223512] pci_bus 0000:00: root bus resource [mem 0xf4000000-0xfe02ffff window]
[    0.223530] pci 0000:00:00.0: [10de:03ea] type 00 class 0x050000
[    0.223729] pci 0000:00:01.0: [10de:03e0] type 00 class 0x060100
[    0.223743] pci 0000:00:01.0: reg 0x18: [io  0x1d00-0x1dff]
[    0.223824] pci 0000:00:01.1: [10de:03eb] type 00 class 0x0c0500
[    0.223837] pci 0000:00:01.1: reg 0x10: [io  0xfc00-0xfc3f]
[    0.223850] pci 0000:00:01.1: reg 0x20: [io  0x1c00-0x1c3f]
[    0.223855] pci 0000:00:01.1: reg 0x24: [io  0xf400-0xf43f]
[    0.223872] pci 0000:00:01.1: PME# supported from D3hot D3cold
[    0.223942] pci 0000:00:01.2: [10de:03f5] type 00 class 0x050000
[    0.224026] pci 0000:00:02.0: [10de:03f1] type 00 class 0x0c0310
[    0.224036] pci 0000:00:02.0: reg 0x10: [mem 0xfe02f000-0xfe02ffff]
[    0.224063] pci 0000:00:02.0: supports D1 D2
[    0.224064] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.224103] pci 0000:00:02.0: System wakeup disabled by ACPI
[    0.224137] pci 0000:00:02.1: [10de:03f2] type 00 class 0x0c0320
[    0.224149] pci 0000:00:02.1: reg 0x10: [mem 0xfe02e000-0xfe02e0ff]
[    0.224179] pci 0000:00:02.1: supports D1 D2
[    0.224180] pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold
[    0.224228] pci 0000:00:02.1: System wakeup disabled by ACPI
[    0.224267] pci 0000:00:04.0: [10de:03f3] type 01 class 0x060401
[    0.224326] pci 0000:00:04.0: System wakeup disabled by ACPI
[    0.224359] pci 0000:00:05.0: [10de:03f0] type 00 class 0x040300
[    0.224373] pci 0000:00:05.0: reg 0x10: [mem 0xfe024000-0xfe027fff]
[    0.224402] pci 0000:00:05.0: PME# supported from D3hot D3cold
[    0.224440] pci 0000:00:05.0: System wakeup disabled by ACPI
[    0.224480] pci 0000:00:06.0: [10de:03ec] type 00 class 0x01018a
[    0.224502] pci 0000:00:06.0: reg 0x20: [io  0xf000-0xf00f]
[    0.224511] pci 0000:00:06.0: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
[    0.224512] pci 0000:00:06.0: legacy IDE quirk: reg 0x14: [io  0x03f6]
[    0.224514] pci 0000:00:06.0: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
[    0.224515] pci 0000:00:06.0: legacy IDE quirk: reg 0x1c: [io  0x0376]
[    0.224584] pci 0000:00:07.0: [10de:03ef] type 00 class 0x068000
[    0.224596] pci 0000:00:07.0: reg 0x10: [mem 0xfe02d000-0xfe02dfff]
[    0.224600] pci 0000:00:07.0: reg 0x14: [io  0xec00-0xec07]
[    0.224621] pci 0000:00:07.0: supports D1 D2
[    0.224622] pci 0000:00:07.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.224661] pci 0000:00:07.0: System wakeup disabled by ACPI
[    0.224694] pci 0000:00:08.0: [10de:03f6] type 00 class 0x010185
[    0.224704] pci 0000:00:08.0: reg 0x10: [io  0x09f0-0x09f7]
[    0.224707] pci 0000:00:08.0: reg 0x14: [io  0x0bf0-0x0bf3]
[    0.224711] pci 0000:00:08.0: reg 0x18: [io  0x0970-0x0977]
[    0.224714] pci 0000:00:08.0: reg 0x1c: [io  0x0b70-0x0b73]
[    0.224718] pci 0000:00:08.0: reg 0x20: [io  0xd800-0xd80f]
[    0.224721] pci 0000:00:08.0: reg 0x24: [mem 0xfe02c000-0xfe02cfff]
[    0.224793] pci 0000:00:08.1: [10de:03f6] type 00 class 0x010185
[    0.224802] pci 0000:00:08.1: reg 0x10: [io  0x09e0-0x09e7]
[    0.224806] pci 0000:00:08.1: reg 0x14: [io  0x0be0-0x0be3]
[    0.224809] pci 0000:00:08.1: reg 0x18: [io  0x0960-0x0967]
[    0.224813] pci 0000:00:08.1: reg 0x1c: [io  0x0b60-0x0b63]
[    0.224816] pci 0000:00:08.1: reg 0x20: [io  0xc400-0xc40f]
[    0.224820] pci 0000:00:08.1: reg 0x24: [mem 0xfe02b000-0xfe02bfff]
[    0.224898] pci 0000:00:09.0: [10de:03e8] type 01 class 0x060400
[    0.224920] pci 0000:00:09.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.224958] pci 0000:00:09.0: System wakeup disabled by ACPI
[    0.224993] pci 0000:00:0b.0: [10de:03e9] type 01 class 0x060400
[    0.225014] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.225051] pci 0000:00:0b.0: System wakeup disabled by ACPI
[    0.225084] pci 0000:00:0c.0: [10de:03e9] type 01 class 0x060400
[    0.225105] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.225143] pci 0000:00:0c.0: System wakeup disabled by ACPI
[    0.225175] pci 0000:00:0d.0: [10de:03d0] type 00 class 0x030000
[    0.225183] pci 0000:00:0d.0: reg 0x10: [mem 0xfb000000-0xfbffffff]
[    0.225188] pci 0000:00:0d.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.225192] pci 0000:00:0d.0: reg 0x1c: [mem 0xfc000000-0xfcffffff 64bit]
[    0.225197] pci 0000:00:0d.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[    0.225274] pci 0000:00:18.0: [1022:1200] type 00 class 0x060000
[    0.225341] pci 0000:00:18.1: [1022:1201] type 00 class 0x060000
[    0.225405] pci 0000:00:18.2: [1022:1202] type 00 class 0x060000
[    0.225469] pci 0000:00:18.3: [1022:1203] type 00 class 0x060000
[    0.225538] pci 0000:00:18.4: [1022:1204] type 00 class 0x060000
[    0.225656] pci 0000:00:04.0: PCI bridge to [bus 01] (subtractive decode)
[    0.225659] pci 0000:00:04.0:   bridge window [io  0xb000-0xbfff]
[    0.225662] pci 0000:00:04.0:   bridge window [mem 0xfd800000-0xfd8fffff]
[    0.225664] pci 0000:00:04.0:   bridge window [mem 0xfdf00000-0xfdffffff pref]
[    0.225666] pci 0000:00:04.0:   bridge window [io  0x0000-0x03af window] (subtractive decode)
[    0.225668] pci 0000:00:04.0:   bridge window [io  0x03e0-0x0cf7 window] (subtractive decode)
[    0.225669] pci 0000:00:04.0:   bridge window [io  0x8000-0xffff window] (subtractive decode)
[    0.225671] pci 0000:00:04.0:   bridge window [io  0x03b0-0x03df window] (subtractive decode)
[    0.225673] pci 0000:00:04.0:   bridge window [io  0x1c00-0x1c80 window] (subtractive decode)
[    0.225674] pci 0000:00:04.0:   bridge window [mem 0xfec80000-0xfecbffff window] (subtractive decode)
[    0.225676] pci 0000:00:04.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.225677] pci 0000:00:04.0:   bridge window [mem 0xc0000000-0xefffffff window] (subtractive decode)
[    0.225679] pci 0000:00:04.0:   bridge window [mem 0xf4000000-0xfe02ffff window] (subtractive decode)
[    0.225708] pci 0000:00:09.0: PCI bridge to [bus 02]
[    0.225711] pci 0000:00:09.0:   bridge window [io  0xa000-0xafff]
[    0.225713] pci 0000:00:09.0:   bridge window [mem 0xfde00000-0xfdefffff]
[    0.225715] pci 0000:00:09.0:   bridge window [mem 0xfdd00000-0xfddfffff 64bit pref]
[    0.225740] pci 0000:00:0b.0: PCI bridge to [bus 03]
[    0.225742] pci 0000:00:0b.0:   bridge window [io  0x9000-0x9fff]
[    0.225744] pci 0000:00:0b.0:   bridge window [mem 0xfdc00000-0xfdcfffff]
[    0.225747] pci 0000:00:0b.0:   bridge window [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.225772] pci 0000:00:0c.0: PCI bridge to [bus 04]
[    0.225774] pci 0000:00:0c.0:   bridge window [io  0x8000-0x8fff]
[    0.225776] pci 0000:00:0c.0:   bridge window [mem 0xfda00000-0xfdafffff]
[    0.225779] pci 0000:00:0c.0:   bridge window [mem 0xfd900000-0xfd9fffff 64bit pref]
[    0.225786] pci_bus 0000:00: on NUMA node 0
[    0.226329] ACPI: PCI Interrupt Link [LNK1] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[    0.226373] ACPI: PCI Interrupt Link [LNK2] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[    0.226415] ACPI: PCI Interrupt Link [LNK3] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[    0.226456] ACPI: PCI Interrupt Link [LNK4] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[    0.226497] ACPI: PCI Interrupt Link [LNK5] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[    0.226539] ACPI: PCI Interrupt Link [LNK6] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[    0.226580] ACPI: PCI Interrupt Link [LNK7] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[    0.226621] ACPI: PCI Interrupt Link [LNK8] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[    0.226663] ACPI: PCI Interrupt Link [LIGP] (IRQs *5 7 9 10 11 14 15)
[    0.226704] ACPI: PCI Interrupt Link [LP2P] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[    0.226746] ACPI: PCI Interrupt Link [LUBA] (IRQs 5 7 9 10 *11 14 15)
[    0.226788] ACPI: PCI Interrupt Link [LMAC] (IRQs 5 7 9 10 11 14 *15)
[    0.226829] ACPI: PCI Interrupt Link [LAZA] (IRQs 5 7 9 10 *11 14 15)
[    0.226870] ACPI: PCI Interrupt Link [LPMU] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[    0.226912] ACPI: PCI Interrupt Link [LSMB] (IRQs 5 7 9 *10 11 14 15)
[    0.226953] ACPI: PCI Interrupt Link [LUB2] (IRQs *5 7 9 10 11 14 15)
[    0.227001] ACPI: PCI Interrupt Link [LIDE] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[    0.227043] ACPI: PCI Interrupt Link [LSID] (IRQs 5 7 9 10 *11 14 15)
[    0.227085] ACPI: PCI Interrupt Link [LFID] (IRQs 5 7 9 *10 11 14 15)
[    0.227154] ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0, disabled.
[    0.227220] ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0, disabled.
[    0.227285] ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0, disabled.
[    0.227350] ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0, disabled.
[    0.227415] ACPI: PCI Interrupt Link [APC5] (IRQs 16) *0, disabled.
[    0.227481] ACPI: PCI Interrupt Link [APC6] (IRQs 16) *0, disabled.
[    0.227546] ACPI: PCI Interrupt Link [APC7] (IRQs 16) *0, disabled.
[    0.227611] ACPI: PCI Interrupt Link [APC8] (IRQs 16) *0, disabled.
[    0.227676] ACPI: PCI Interrupt Link [AIGP] (IRQs 20 21 22) *0, disabled.
[    0.227741] ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22) *0, disabled.
[    0.227807] ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22) *0, disabled.
[    0.227873] ACPI: PCI Interrupt Link [APMU] (IRQs 20 21 22) *0, disabled.
[    0.227939] ACPI: PCI Interrupt Link [AAZA] (IRQs 20 21 22) *0, disabled.
[    0.228004] ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22) *0, disabled.
[    0.228070] ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22) *0, disabled.
[    0.228136] ACPI: PCI Interrupt Link [APCM] (IRQs 20 21 22) *0, disabled.
[    0.228202] ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22) *0, disabled.
[    0.228268] ACPI: PCI Interrupt Link [APSI] (IRQs 23) *0, disabled.
[    0.228333] ACPI: PCI Interrupt Link [APSJ] (IRQs 23) *0, disabled.
[    0.228401] ACPI: Enabled 1 GPEs in block 00 to 1F
[    0.228546] vgaarb: setting as boot device: PCI:0000:00:0d.0
[    0.228548] vgaarb: device added: PCI:0000:00:0d.0,decodes=io+mem,owns=io+mem,locks=none
[    0.228549] vgaarb: loaded
[    0.228550] vgaarb: bridge control possible 0000:00:0d.0
[    0.228694] PCI: Using ACPI for IRQ routing
[    0.230118] PCI: pci_cache_line_size set to 64 bytes
[    0.230127] pci 0000:00:01.0: can't claim BAR 2 [io  0x1d00-0x1dff]: no compatible bridge window
[    0.230152] e820: reserve RAM buffer [mem 0x0009f400-0x0009ffff]
[    0.230153] e820: reserve RAM buffer [mem 0xb7ee0000-0xb7ffffff]
[    0.230301] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[    0.230306] hpet0: at MMIO 0xfeff0000, IRQs 2, 8, 31
[    0.230309] hpet0: 3 comparators, 32-bit 25.000000 MHz counter
[    0.232416] clocksource: Switched to clocksource hpet
[    0.238968] pnp: PnP ACPI init
[    0.239150] system 00:00: [io  0x1000-0x107f] has been reserved
[    0.239152] system 00:00: [io  0x1080-0x10ff] has been reserved
[    0.239154] system 00:00: [io  0x1400-0x147f] has been reserved
[    0.239156] system 00:00: [io  0x1480-0x14ff] has been reserved
[    0.239157] system 00:00: [io  0x1800-0x187f] has been reserved
[    0.239159] system 00:00: [io  0x1880-0x18ff] has been reserved
[    0.239161] system 00:00: [io  0x2000-0x207f] has been reserved
[    0.239162] system 00:00: [io  0x2080-0x20ff] has been reserved
[    0.239166] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.239237] system 00:01: [io  0x04d0-0x04d1] has been reserved
[    0.239239] system 00:01: [io  0x0800-0x087f] has been reserved
[    0.239242] system 00:01: [io  0x0290-0x029f] has been reserved
[    0.239243] system 00:01: [io  0x0290-0x0297] has been reserved
[    0.239245] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.239304] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.239449] pnp 00:03: [dma 2]
[    0.239476] pnp 00:03: Plug and Play ACPI device, IDs PNP0700 (active)
[    0.239696] pnp 00:04: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.239916] pnp 00:05: Plug and Play ACPI device, IDs PNP0400 (active)
[    0.240031] pnp 00:06: Plug and Play ACPI device, IDs PNP0f13 (active)
[    0.240065] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[    0.240563] system 00:08: [mem 0xf0000000-0xf3ffffff] has been reserved
[    0.240565] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.240655] system 00:09: [mem 0x000f0000-0x000fffff] could not be reserved
[    0.240658] system 00:09: [mem 0xfeff0000-0xfeff00ff] has been reserved
[    0.240660] system 00:09: [mem 0xb7ee0000-0xb7efffff] could not be reserved
[    0.240661] system 00:09: [mem 0xffff0000-0xffffffff] has been reserved
[    0.240663] system 00:09: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.240665] system 00:09: [mem 0x00100000-0xb7edffff] could not be reserved
[    0.240667] system 00:09: [mem 0xb8000000-0xbfffffff] has been reserved
[    0.240669] system 00:09: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.240670] system 00:09: [mem 0xfee00000-0xfeefffff] has been reserved
[    0.240673] system 00:09: [mem 0xfefff000-0xfeffffff] has been reserved
[    0.240675] system 00:09: [mem 0xfff80000-0xfff80fff] has been reserved
[    0.240677] system 00:09: [mem 0xfff90000-0xfffbffff] has been reserved
[    0.240678] system 00:09: [mem 0xfffed000-0xfffeffff] has been reserved
[    0.240680] system 00:09: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.240688] pnp: PnP ACPI: found 10 devices
[    0.247239] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.247264] pci 0000:00:0d.0: BAR 6: assigned [mem 0xc0000000-0xc001ffff pref]
[    0.247267] pci 0000:00:01.0: BAR 2: assigned [io  0xc000-0xc0ff]
[    0.247271] pci 0000:00:04.0: PCI bridge to [bus 01]
[    0.247273] pci 0000:00:04.0:   bridge window [io  0xb000-0xbfff]
[    0.247276] pci 0000:00:04.0:   bridge window [mem 0xfd800000-0xfd8fffff]
[    0.247278] pci 0000:00:04.0:   bridge window [mem 0xfdf00000-0xfdffffff pref]
[    0.247281] pci 0000:00:09.0: PCI bridge to [bus 02]
[    0.247283] pci 0000:00:09.0:   bridge window [io  0xa000-0xafff]
[    0.247285] pci 0000:00:09.0:   bridge window [mem 0xfde00000-0xfdefffff]
[    0.247287] pci 0000:00:09.0:   bridge window [mem 0xfdd00000-0xfddfffff 64bit pref]
[    0.247290] pci 0000:00:0b.0: PCI bridge to [bus 03]
[    0.247291] pci 0000:00:0b.0:   bridge window [io  0x9000-0x9fff]
[    0.247293] pci 0000:00:0b.0:   bridge window [mem 0xfdc00000-0xfdcfffff]
[    0.247295] pci 0000:00:0b.0:   bridge window [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.247298] pci 0000:00:0c.0: PCI bridge to [bus 04]
[    0.247300] pci 0000:00:0c.0:   bridge window [io  0x8000-0x8fff]
[    0.247302] pci 0000:00:0c.0:   bridge window [mem 0xfda00000-0xfdafffff]
[    0.247304] pci 0000:00:0c.0:   bridge window [mem 0xfd900000-0xfd9fffff 64bit pref]
[    0.247307] pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
[    0.247308] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
[    0.247310] pci_bus 0000:00: resource 6 [io  0x8000-0xffff window]
[    0.247312] pci_bus 0000:00: resource 7 [io  0x03b0-0x03df window]
[    0.247313] pci_bus 0000:00: resource 8 [io  0x1c00-0x1c80 window]
[    0.247315] pci_bus 0000:00: resource 9 [mem 0xfec80000-0xfecbffff window]
[    0.247316] pci_bus 0000:00: resource 10 [mem 0x000a0000-0x000bffff window]
[    0.247318] pci_bus 0000:00: resource 11 [mem 0xc0000000-0xefffffff window]
[    0.247319] pci_bus 0000:00: resource 12 [mem 0xf4000000-0xfe02ffff window]
[    0.247321] pci_bus 0000:01: resource 0 [io  0xb000-0xbfff]
[    0.247323] pci_bus 0000:01: resource 1 [mem 0xfd800000-0xfd8fffff]
[    0.247324] pci_bus 0000:01: resource 2 [mem 0xfdf00000-0xfdffffff pref]
[    0.247326] pci_bus 0000:01: resource 4 [io  0x0000-0x03af window]
[    0.247327] pci_bus 0000:01: resource 5 [io  0x03e0-0x0cf7 window]
[    0.247329] pci_bus 0000:01: resource 6 [io  0x8000-0xffff window]
[    0.247330] pci_bus 0000:01: resource 7 [io  0x03b0-0x03df window]
[    0.247332] pci_bus 0000:01: resource 8 [io  0x1c00-0x1c80 window]
[    0.247333] pci_bus 0000:01: resource 9 [mem 0xfec80000-0xfecbffff window]
[    0.247335] pci_bus 0000:01: resource 10 [mem 0x000a0000-0x000bffff window]
[    0.247336] pci_bus 0000:01: resource 11 [mem 0xc0000000-0xefffffff window]
[    0.247338] pci_bus 0000:01: resource 12 [mem 0xf4000000-0xfe02ffff window]
[    0.247340] pci_bus 0000:02: resource 0 [io  0xa000-0xafff]
[    0.247341] pci_bus 0000:02: resource 1 [mem 0xfde00000-0xfdefffff]
[    0.247343] pci_bus 0000:02: resource 2 [mem 0xfdd00000-0xfddfffff 64bit pref]
[    0.247344] pci_bus 0000:03: resource 0 [io  0x9000-0x9fff]
[    0.247346] pci_bus 0000:03: resource 1 [mem 0xfdc00000-0xfdcfffff]
[    0.247347] pci_bus 0000:03: resource 2 [mem 0xfdb00000-0xfdbfffff 64bit pref]
[    0.247349] pci_bus 0000:04: resource 0 [io  0x8000-0x8fff]
[    0.247351] pci_bus 0000:04: resource 1 [mem 0xfda00000-0xfdafffff]
[    0.247352] pci_bus 0000:04: resource 2 [mem 0xfd900000-0xfd9fffff 64bit pref]
[    0.247415] NET: Registered protocol family 2
[    0.247592] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.247701] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.247865] TCP: Hash tables configured (established 32768 bind 32768)
[    0.247919] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.247950] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.248058] NET: Registered protocol family 1
[    0.316592] pci 0000:00:00.0: Found enabled HT MSI Mapping
[    0.316636] pci 0000:00:00.0: Found enabled HT MSI Mapping
[    0.316684] pci 0000:00:00.0: Found enabled HT MSI Mapping
[    0.316731] pci 0000:00:00.0: Found enabled HT MSI Mapping
[    0.316777] pci 0000:00:00.0: Found enabled HT MSI Mapping
[    0.316825] pci 0000:00:00.0: Found enabled HT MSI Mapping
[    0.316876] pci 0000:00:00.0: Found enabled HT MSI Mapping
[    0.316929] pci 0000:00:00.0: Found enabled HT MSI Mapping
[    0.316934] pci 0000:00:0d.0: Video device with shadowed ROM
[    0.316945] PCI: CLS 64 bytes, default 64
[    0.317008] Unpacking initramfs...
[    0.628800] Freeing initrd memory: 20760K (ffff880035764000 - ffff880036baa000)
[    0.629124] ACPI: PCI Interrupt Link [APCS] enabled at IRQ 22
[    0.629343] ACPI: PCI Interrupt Link [APCF] enabled at IRQ 21
[    0.629532] ACPI: PCI Interrupt Link [APCL] enabled at IRQ 20
[    0.629726] ACPI: PCI Interrupt Link [AAZA] enabled at IRQ 22
[    0.629918] ACPI: PCI Interrupt Link [APCH] enabled at IRQ 21
[    0.630106] ACPI: PCI Interrupt Link [APSI] enabled at IRQ 23
[    0.630292] ACPI: PCI Interrupt Link [APSJ] enabled at IRQ 23
[    0.630495] ACPI: PCI Interrupt Link [AIGP] enabled at IRQ 20
[    0.630673] microcode: CPU0: patch_level=0x00000000
[    0.630681] microcode: CPU1: patch_level=0x00000000
[    0.630752] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    0.630757] LVT offset 1 assigned for vector 0x400
[    0.630760] IBS: LVT offset 1 assigned
[    0.630770] perf: AMD IBS detected (0x0000001f)
[    0.631034] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.631075] audit: initializing netlink subsys (disabled)
[    0.631100] audit: type=2000 audit(1453814572.524:1): initialized
[    0.631434] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.631458] zbud: loaded
[    0.631595] VFS: Disk quotas dquot_6.6.0
[    0.631610] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.632061] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.632100] io scheduler noop registered
[    0.632103] io scheduler deadline registered
[    0.632114] io scheduler cfq registered (default)
[    0.632328] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.632335] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.632392] GHES: HEST is not enabled!
[    0.632461] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.652823] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.653217] Linux agpgart interface v0.103
[    0.653254] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.653255] AMD IOMMUv2 functionality not available on this system
[    0.653477] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    0.653889] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.653894] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.654006] mousedev: PS/2 mouse device common for all mice
[    0.654053] rtc_cmos 00:02: RTC can wake from S4
[    0.654198] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[    0.654236] rtc_cmos 00:02: alarms up to one year, y3k, 242 bytes nvram, hpet irqs
[    0.654247] ledtrig-cpu: registered to indicate activity on CPUs
[    0.654622] NET: Registered protocol family 10
[    0.654804] mip6: Mobile IPv6
[    0.654813] NET: Registered protocol family 17
[    0.654818] mpls_gso: MPLS GSO support
[    0.655082] registered taskstats version 1
[    0.655108] zswap: loaded using pool lzo/zbud
[    0.655415] rtc_cmos 00:02: setting system clock to 2016-01-26 13:22:52 UTC (1453814572)
[    0.655475] PM: Hibernation image not present or could not be loaded.
[    0.655905] Freeing unused kernel memory: 1304K (ffffffff81b19000 - ffffffff81c5f000)
[    0.655909] Write protecting the kernel read-only data: 10240k
[    0.656185] Freeing unused kernel memory: 440K (ffff880001592000 - ffff880001600000)
[    0.656678] Freeing unused kernel memory: 1284K (ffff8800018bf000 - ffff880001a00000)
[    0.672584] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    0.716045] systemd-udevd[68]: starting version 215
[    0.716337] random: systemd-udevd urandom read with 2 bits of entropy available
[    0.728131] ACPI: bus type USB registered
[    0.728157] usbcore: registered new interface driver usbfs
[    0.728167] usbcore: registered new interface driver hub
[    0.730088] SCSI subsystem initialized
[    0.731987] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
[    0.732987] libata version 3.00 loaded.
[    0.734674] usbcore: registered new device driver usb
[    0.735199] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.735417] ehci-pci: EHCI PCI platform driver
[    0.735523] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.744996] ACPI: Invalid passive threshold
[    0.745178] thermal LNXTHERM:00: registered as thermal_zone0
[    0.745179] ACPI: Thermal Zone [THRM] (40 C)
[    0.768512] FDC 0 is a post-1991 82077
[    1.253935] forcedeth 0000:00:07.0: ifname eth0, PHY OUI 0x732 @ 1, addr 00:30:67:60:9a:7e
[    1.253940] forcedeth 0000:00:07.0: highdma pwrctl mgmt lnktim msi desc-v3
[    1.254086] sata_nv 0000:00:08.0: version 3.5
[    1.254426] scsi host0: sata_nv
[    1.254519] scsi host1: sata_nv
[    1.254557] ata1: SATA max UDMA/133 cmd 0x9f0 ctl 0xbf0 bmdma 0xd800 irq 23
[    1.254559] ata2: SATA max UDMA/133 cmd 0x970 ctl 0xb70 bmdma 0xd808 irq 23
[    1.254848] scsi host2: sata_nv
[    1.254922] scsi host3: sata_nv
[    1.254973] ata3: SATA max UDMA/133 cmd 0x9e0 ctl 0xbe0 bmdma 0xc400 irq 23
[    1.254975] ata4: SATA max UDMA/133 cmd 0x960 ctl 0xb60 bmdma 0xc408 irq 23
[    1.255085] pata_amd 0000:00:06.0: version 0.4.1
[    1.255687] scsi host4: pata_amd
[    1.255765] scsi host5: pata_amd
[    1.255819] ata5: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14
[    1.255821] ata6: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15
[    1.255945] ehci-pci 0000:00:02.1: EHCI Host Controller
[    1.255951] ehci-pci 0000:00:02.1: new USB bus registered, assigned bus number 1
[    1.255962] ehci-pci 0000:00:02.1: debug port 1
[    1.255988] ehci-pci 0000:00:02.1: cache line size of 64 is not supported
[    1.256006] ehci-pci 0000:00:02.1: irq 20, io mem 0xfe02e000
[    1.265206] ehci-pci 0000:00:02.1: USB 2.0 started, EHCI 1.00
[    1.265339] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.265343] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.265344] usb usb1: Product: EHCI Host Controller
[    1.265346] usb usb1: Manufacturer: Linux 4.3.0-0.bpo.1-amd64 ehci_hcd
[    1.265347] usb usb1: SerialNumber: 0000:00:02.1
[    1.265499] hub 1-0:1.0: USB hub found
[    1.265505] hub 1-0:1.0: 10 ports detected
[    1.266361] ohci-pci: OHCI PCI platform driver
[    1.266476] ohci-pci 0000:00:02.0: OHCI PCI host controller
[    1.266482] ohci-pci 0000:00:02.0: new USB bus registered, assigned bus number 2
[    1.266519] ohci-pci 0000:00:02.0: irq 21, io mem 0xfe02f000
[    1.323266] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.323269] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.323271] usb usb2: Product: OHCI PCI host controller
[    1.323272] usb usb2: Manufacturer: Linux 4.3.0-0.bpo.1-amd64 ohci_hcd
[    1.323274] usb usb2: SerialNumber: 0000:00:02.0
[    1.323451] hub 2-0:1.0: USB hub found
[    1.323458] hub 2-0:1.0: 10 ports detected
[    1.426501] ata5.01: ATA-5: WDC WD800JB-00CRA1, 17.07W17, max UDMA/100
[    1.426506] ata5.01: 156301488 sectors, multi 16: LBA
[    1.426513] ata5: nv_mode_filter: 0x3f39f&0x3f39f->0x3f39f, BIOS=0x3f000 (0xc60000) ACPI=0x3f01f (600:20:0x1c)
[    1.442451] ata5.01: configured for UDMA/100
[    1.575676] ata1: SATA link down (SStatus 0 SControl 300)
[    1.629446] tsc: Refined TSC clocksource calibration: 3013.888 MHz
[    1.629451] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b7184de1e7, max_idle_ns: 440795356024 ns
[    1.721532] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.729644] ata3.00: ATAPI: ASUS    DRW-24B1ST, 1.03, max UDMA/100
[    1.745656] ata3.00: configured for UDMA/100
[    2.041773] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.049966] ata2.00: HPA detected: current 488395055, native 488397168
[    2.049971] ata2.00: ATA-7: ST3250410AS, 4.AAA, max UDMA/133
[    2.049973] ata2.00: 488395055 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    2.065987] ata2.00: configured for UDMA/133
[    2.066193] scsi 1:0:0:0: Direct-Access     ATA      ST3250410AS      A    PQ: 0 ANSI: 5
[    2.067224] sd 1:0:0:0: [sda] 488395055 512-byte logical blocks: (250 GB/232 GiB)
[    2.067298] sd 1:0:0:0: [sda] Write Protect is off
[    2.067300] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.067328] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.069298] scsi 2:0:0:0: CD-ROM            ASUS     DRW-24B1ST       1.03 PQ: 0 ANSI: 5
[    2.072018]  sda: sda1 sda2 sda4
[    2.072391] sd 1:0:0:0: [sda] Attached SCSI disk
[    2.400244] ata4: SATA link down (SStatus 0 SControl 300)
[    2.400497] scsi 4:0:1:0: Direct-Access     ATA      WDC WD800JB-00CR 7W17 PQ: 0 ANSI: 5
[    2.400741] sd 4:0:1:0: [sdb] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
[    2.400788] ata6: port disabled--ignoring
[    2.400803] sd 4:0:1:0: [sdb] Write Protect is off
[    2.400806] sd 4:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[    2.400833] sd 4:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.418117]  sdb: sdb2 sdb3
[    2.418485] sd 4:0:1:0: [sdb] Attached SCSI disk
[    2.419919] sd 1:0:0:0: Attached scsi generic sg0 type 0
[    2.420381] scsi 2:0:0:0: Attached scsi generic sg1 type 5
[    2.420423] sd 4:0:1:0: Attached scsi generic sg2 type 0
[    2.432869] sr 2:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[    2.432874] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.433027] sr 2:0:0:0: Attached scsi CD-ROM sr0
[    2.630222] clocksource: Switched to clocksource tsc
[    2.921389] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
[    3.619316] random: nonblocking pool is initialized
[    5.597103] lp: driver loaded but no devices found
[    5.680518] ppdev: user-space parallel port driver
[    5.699345] parport_pc 00:05: reported by Plug and Play ACPI
[    5.699410] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[    5.786206] systemd-udevd[192]: starting version 215
[    5.796510] lp0: using parport0 (interrupt-driven).
[    5.959504] fuse init (API version 7.23)
[    6.691941] acpi-cpufreq: overriding BIOS provided _PSD data
[    6.921074] i2c i2c-0: nForce2 SMBus adapter at 0x1c00
[    6.921187] i2c i2c-1: nForce2 SMBus adapter at 0xf400
[    6.942001] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    7.025244] EDAC MC: Ver: 3.0.0
[    7.046820] MCE: In-kernel MCE decoding enabled.
[    7.070521] AMD64 EDAC driver v3.4.0
[    7.070590] EDAC amd64: DRAM ECC disabled.
[    7.070601] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
 Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
 (Note that use of the override may cause unknown side effects.)
[    7.128195] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[    7.128210] ACPI: Power Button [PWRB]
[    7.128395] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    7.128402] ACPI: Power Button [PWRF]
[    7.183584] snd_hda_intel 0000:00:05.0: Disabling MSI
[    7.209966] input: PC Speaker as /devices/platform/pcspkr/input/input4
[    7.489923] kvm: Nested Virtualization enabled
[    7.489935] kvm: Nested Paging enabled
[    7.751361] [drm] Initialized drm 1.1.0 20060810
[    7.907571] wmi: Mapper loaded
[    7.929943] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC662 rev1: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    7.929957] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    7.929964] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    7.929970] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    7.929975] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x1e/0x0
[    7.929979] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    7.929987] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    7.929993] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    7.929998] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    8.037183] nouveau 0000:00:0d.0: NVIDIA C61 (04c000a2)
[    8.047867] nouveau 0000:00:0d.0: bios: version 05.61.32.22.01
[    8.048168] nouveau 0000:00:0d.0: disp: dcb 1 type 4 unknown
[    8.048752] nouveau 0000:00:0d.0: fb: 128 MiB of unknown memory type
[    8.088096] EXT4-fs (sdb2): re-mounted. Opts: errors=remount-ro
[    8.100856] [TTM] Zone  kernel: Available graphics memory: 1477314 kiB
[    8.100858] [TTM] Initializing pool allocator
[    8.100863] [TTM] Initializing DMA pool allocator
[    8.100875] nouveau 0000:00:0d.0: DRM: VRAM: 125 MiB
[    8.100876] nouveau 0000:00:0d.0: DRM: GART: 512 MiB
[    8.100880] nouveau 0000:00:0d.0: DRM: TMDS table version 1.1
[    8.100881] nouveau 0000:00:0d.0: DRM: DCB version 3.0
[    8.100883] nouveau 0000:00:0d.0: DRM: DCB outp 00: 01000310 00000023
[    8.100886] nouveau 0000:00:0d.0: DRM: DCB outp 01: 00110204 97e50000
[    8.100887] nouveau 0000:00:0d.0: DRM: DCB conn 00: 0000
[    8.101082] nouveau 0000:00:0d.0: DRM: Saving VGA fonts
[    8.138752] nouveau 0000:00:0d.0: DRM: DCB type 4 not known
[    8.138754] nouveau 0000:00:0d.0: DRM: Unknown-1 has no encoders, removing
[    8.139580] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    8.139581] [drm] Driver supports precise vblank timestamp query.
[    8.141178] nouveau 0000:00:0d.0: DRM: MM: using M2MF for buffer copies
[    8.170604] nouveau 0000:00:0d.0: DRM: allocated 1280x1024 fb: 0x9000, bo ffff8800b1db2800
[    8.170669] fbcon: nouveaufb (fb0) is primary device
[    8.281339] Console: switching to colour frame buffer device 160x64
[    8.282898] nouveau 0000:00:0d.0: fb0: nouveaufb frame buffer device
[    8.302197] [drm] Initialized nouveau 1.3.0 20120801 for 0000:00:0d.0 on minor 0
[    8.357750] input: ImPS/2 Logitech Wheel Mouse as /devices/platform/i8042/serio1/input/input5
[    8.651243] systemd-journald[189]: Received request to flush runtime journal from PID 1
[    8.936906] ip_tables: (C) 2000-2006 Netfilter Core Team
[    9.177487] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    9.262827] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    9.372335] input: HDA NVidia Front Mic as /devices/pci0000:00/0000:00:05.0/sound/card0/input6
[    9.372538] input: HDA NVidia Rear Mic as /devices/pci0000:00/0000:00:05.0/sound/card0/input7
[    9.372718] input: HDA NVidia Line as /devices/pci0000:00/0000:00:05.0/sound/card0/input8
[    9.372912] input: HDA NVidia Line Out as /devices/pci0000:00/0000:00:05.0/sound/card0/input9
[    9.373079] input: HDA NVidia Front Headphone as /devices/pci0000:00/0000:00:05.0/sound/card0/input10
[   15.847137] forcedeth 0000:00:07.0 eth0: MSI enabled
[   17.870996] nouveau 0000:00:0d.0: bus: MMIO write of 00540001 FAULT at 00b000
[   22.457922] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[   23.485235] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.50 DST=96.2.71.33 LEN=276 TOS=0x00 PREC=0xC0 TTL=60 ID=29591 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.50 LEN=248 TOS=0x00 PREC=0x00 TTL=60 ID=39713 DF PROTO=UDP SPT=138 DPT=138 LEN=228 ]
[   23.485274] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.50 DST=96.2.71.33 LEN=106 TOS=0x00 PREC=0xC0 TTL=60 ID=29592 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.50 LEN=78 TOS=0x00 PREC=0x00 TTL=60 ID=39714 DF PROTO=UDP SPT=137 DPT=137 LEN=58 ]
[   23.488380] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.52 DST=96.2.71.33 LEN=276 TOS=0x00 PREC=0x00 TTL=60 ID=58625 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.52 LEN=248 TOS=0x00 PREC=0x00 TTL=60 ID=39713 DF PROTO=UDP SPT=138 DPT=138 LEN=228 ]
[   23.488414] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.52 DST=96.2.71.33 LEN=106 TOS=0x00 PREC=0x00 TTL=60 ID=58626 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.52 LEN=78 TOS=0x00 PREC=0x00 TTL=60 ID=39714 DF PROTO=UDP SPT=137 DPT=137 LEN=58 ]
[   24.479199] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.50 DST=96.2.71.33 LEN=124 TOS=0x00 PREC=0xC0 TTL=60 ID=29593 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.50 LEN=96 TOS=0x00 PREC=0x00 TTL=60 ID=39917 DF PROTO=UDP SPT=137 DPT=137 LEN=76 ]
[   24.481171] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.52 DST=96.2.71.33 LEN=124 TOS=0x00 PREC=0x00 TTL=60 ID=58627 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.52 LEN=96 TOS=0x00 PREC=0x00 TTL=60 ID=39917 DF PROTO=UDP SPT=137 DPT=137 LEN=76 ]
[   25.482263] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.50 DST=96.2.71.33 LEN=124 TOS=0x00 PREC=0xC0 TTL=60 ID=29594 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.50 LEN=96 TOS=0x00 PREC=0x00 TTL=60 ID=39954 DF PROTO=UDP SPT=137 DPT=137 LEN=76 ]
[   25.483965] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.52 DST=96.2.71.33 LEN=124 TOS=0x00 PREC=0x00 TTL=60 ID=58628 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.52 LEN=96 TOS=0x00 PREC=0x00 TTL=60 ID=39954 DF PROTO=UDP SPT=137 DPT=137 LEN=76 ]
[   26.485767] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.50 DST=96.2.71.33 LEN=124 TOS=0x00 PREC=0xC0 TTL=60 ID=29595 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.50 LEN=96 TOS=0x00 PREC=0x00 TTL=60 ID=40093 DF PROTO=UDP SPT=137 DPT=137 LEN=76 ]
[   26.487007] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.52 DST=96.2.71.33 LEN=124 TOS=0x00 PREC=0x00 TTL=60 ID=58629 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.52 LEN=96 TOS=0x00 PREC=0x00 TTL=60 ID=40093 DF PROTO=UDP SPT=137 DPT=137 LEN=76 ]
[   36.784874] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=109.248.20.226 DST=96.2.71.33 LEN=29 TOS=0x00 PREC=0x00 TTL=41 ID=20610 DF PROTO=UDP SPT=3493 DPT=53413 LEN=9
[   39.258754] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=109.248.20.226 DST=96.2.71.33 LEN=29 TOS=0x00 PREC=0x00 TTL=41 ID=20611 DF PROTO=UDP SPT=3493 DPT=53413 LEN=9
[   42.217643] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=109.248.20.226 DST=96.2.71.33 LEN=29 TOS=0x00 PREC=0x00 TTL=41 ID=20612 DF PROTO=UDP SPT=3493 DPT=53413 LEN=9
[   43.510904] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.52 DST=96.2.71.33 LEN=251 TOS=0x00 PREC=0x00 TTL=60 ID=58634 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.52 LEN=223 TOS=0x00 PREC=0x00 TTL=60 ID=40706 DF PROTO=UDP SPT=138 DPT=138 LEN=203 ]
[   65.539287] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=10.54.1.52 DST=96.2.71.33 LEN=276 TOS=0x00 PREC=0x00 TTL=60 ID=58645 PROTO=ICMP TYPE=3 CODE=3 [SRC=96.2.71.33 DST=10.54.1.52 LEN=248 TOS=0x00 PREC=0x00 TTL=60 ID=42843 DF PROTO=UDP SPT=138 DPT=138 LEN=228 ]
[  101.286789] [UFW BLOCK] IN=eth0 OUT= MAC=00:30:67:60:9a:7e:68:ef:bd:ef:e7:d9:08:00 SRC=184.105.139.123 DST=96.2.71.33 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=54321 PROTO=TCP SPT=52372 DPT=11211 WINDOW=65535 RES=0x00 SYN URGP=0
[  102.085337] usb 1-5: new high-speed USB device number 2 using ehci-pci
[  102.219311] usb 1-5: New USB device found, idVendor=05e3, idProduct=0718
[  102.219318] usb 1-5: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[  102.219320] usb 1-5: Product: USB Storage
[  102.219322] usb 1-5: SerialNumber: 000000000033
[  102.370149] usb-storage 1-5:1.0: USB Mass Storage device detected
[  102.370342] scsi host6: usb-storage 1-5:1.0
[  102.370557] usbcore: registered new interface driver usb-storage
[  102.380145] usbcore: registered new interface driver uas
[  103.372466] scsi 6:0:0:0: Direct-Access     IC35L060 AVV207-0         0041 PQ: 0 ANSI: 0
[  103.373433] sd 6:0:0:0: Attached scsi generic sg3 type 0
[  103.374379] sd 6:0:0:0: [sdc] 117187500 512-byte logical blocks: (60.0 GB/55.8 GiB)
[  103.376816] sd 6:0:0:0: [sdc] Write Protect is off
[  103.376820] sd 6:0:0:0: [sdc] Mode Sense: 03 00 00 00
[  103.377757] sd 6:0:0:0: [sdc] No Caching mode page found
[  103.377761] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[  134.123919] usb 1-5: reset high-speed USB device number 2 using ehci-pci
[  165.098268] usb 1-5: reset high-speed USB device number 2 using ehci-pci
mc@q4os-desktop:~$
Q4OS running Xfce
#4 2016-01-26 17:00
Are you able to mount the drive manually ?
$ sudo mkdir /mnt/work
$ sudo mount /dev/sdc1 /mnt/work
#5 2016-01-26 19:15
q4os_user
$ lsusb
$ dmesg
Sorry, I was wrong--the CD-ROM drive started to work, and HDD doesn't actually seem too work on Windows either... I will update this thread if I'm sure that this a Q4OS issue.
#6 2016-01-26 19:21
q4os_user
Could you also try this procedure:
"First things first (besides the select jumpers) - are you following the proper power-up sequence?
Connect the IDE-USB adapter to the HDD. Then apply power to the HDD; the HDD must be spinning and ready (heads unlocked) before you plug in the USB cable at the PC.
And be very careful to not jostle the drive while it is powered on!"
#7 2016-01-26 21:09
MC
UPDATE.
It turns out the first external (loose) HDD I tested was corrupt. I tried a second loose HDD and all is well.
Q4OS running Xfce
