#1 2018-11-09 17:40
rafaelramos
Gedit settings are not saving on x64 r4 version
Dears,
I noticed that in this latest version of Q4OS (q4os-2.6-x64-instcd.r4.iso) there is a bug to save the settings in Gedit (version 3.22, the same version that was present in version r3 and that the bug did not happen).
I open the "Preferences" window and change the options I want, and close the window.
But the changes are not getting saved, they always return to the default when I close Gedit.
If I go in the terminal and give a "sudo gedit" there I can save the options normally...
It seems to be some permission problem...
Any idea of contouring solution?
Att.;
Rafael
#2 2018-11-10 15:23
Re: Gedit settings are not saving on x64 r4 version
We can confirm the issue. It looks like a bug in Gedit, as it doesn't respect the XDG home configuration. You could workaround this bug temporarily adding the command "unset XDG_CONFIG_HOME" in the "/usr/share/applications/org.gnome.gedit.desktop" desktop shortcut, so the exec lines will look like this:
Exec=unset XDG_CONFIG_HOME ; gedit ...
You can verify the workaround above running in terminal:
$ unset XDG_CONFIG_HOME ; gedit
We will try to search a solution and report back, if find something new.
#3 2018-11-11 03:19
rafaelramos
Hi guys, thank you for the feedback.
Just a minor correction: the version that did not appear in this bug was "2.6 r1", not "2.6 r3" as I had reported...
Actually I did not test on r3, I went straight from r1 to r4 and I noticed the issue.
The curious is why this did not happen in r1...
What might have been changed from r1 to r4 that might be causing this issue?
Rafael
#4 2018-11-12 10:30
The change is Q4OS uses another "XDG_CONFIG_HOME" location starting from "r2" revision.
#5 2018-11-29 09:52
The issue is now fixed, you only need to update your system, so run in terminal:
$ sudo apt-get update
$ sudo apt-get dist-upgrade
Reboot.
#6 2018-11-30 14:57
rafaelramos
Great guys!
This bug was particularly annoying for me, because I use Gedit a lot to program small routines in PHP and to edit HTML ...
This fix will be present in the next r5 release, right?
Thanks for the correction!
#7 2018-11-30 16:03
Definitely.
#8 2018-12-06 20:58
rafaelramos
Curious...
I did a clean r4 install now, applied the Full Profile, and then I installed GEdit.
I went to test and the GEdit options were recording normally, without any issue. Wonderful! big_smile
The funny thing is that I have NOT given the command "apt-get dist-upgrade"...
When applying the Full Profile does it automatically perform a "dist-upgrade" during the process?
#9 2018-12-07 08:27
Yes, your system has been upgraded along with the full desktop profile installation, so it has got all fixes from repositories as well, nothing curious.
#10 2018-12-07 17:28
rafaelramos
Interesting!
