#1 2016-01-25 20:18
After update can not change Konsole colour theme.
Updated to 1.4.6.
Previously I was able to change the default Konsole colour scheme. Now, I change colour scheme to 'Black on white' for example, hit 'Save parameters', but colour scheme is changing only to current session. When I close Konsole and open it again, colour scheme is reverted to default white on black scheme. It does not save anymore...
#2 2016-01-25 21:10
Re: After update can not change Konsole colour theme.
Right mouse click on the konsole -> Settings -> Configure konsole -> Session tab -> set 'Schema' combobox to 'Black on white' -> Ok -> Save -> Restart konsole
Works fine here.
#3 2016-01-26 10:32
Thank You! It works now. I just tried to change colour scheme using only 'Settings' menu, not through 'Configure konsole'.
