Q4os trinity KD.
Can I get all the installed packages (programs) into a simple list' so they can be easily found and fired up as chosen?
The problem is for a new user used to Windows XP is finding anything. There are folders etc but you have to know the system prior
to be able to find things quick sharp.
Iv used the Synaptic Package Manager to install things, and I cant find them.
A really idiotic problem to people who know the system but for me its really annoying, sorry!
One thing you could try is from the Welcome Screen select Switch to Kickoff start menu and choose menu type classic and Menu Structure Categories this might give you a more intuitive "windows style" start menu.
Many thanks for taking the trouble to reply and giving me a pointer!
I will have another go at it when time allows..
I thought Id use ShotCut video editor as a system test, so far as I couldn't even
find it after installation! C+
Shotcut is not available from the normal repositories but the download section of their site offers a portable version, a flatpak version, an appimage or a snap package, so it would depend on the version you are using on where you can find it and you might need to perform some after download extra steps depending on which one you have.
I have OpenShot on my system and although I do not use it extensively it has helped with a few small video projects and has worked well for my use. There are also a few others in the repositories (easier installation) like pitivi, kino, kdenlive and gopchop but it depend on what your needs are as to whether they would be suitable for you.
Sorry memory let me down - I meant Openshot not the shotcut I quoted!
Thanks
In your start menu you should find OpenShot under Multimedia using the menu structure posted earlier, or Programs -> Accessories -> Multimedia with standard Q4OS menu structure.
If you use Bourbon or KickOff as a menu you could start to type the name of the package in the search box at the bottom (top for KickOff) and it should filter out other packages and leave only ones matching your text. Otherwise the location is Applications -> Programs -> Accessories -> Multimedia or Applications -> Multimedia depending on the menu structure you are using.
Really helpful post for a new user, thank you.
Am away for a bit and will have a 'go' on return! C+
@ChasG:
Have you tried using the Run utility to find and execute applications?
Just hit <ALT><F2> and enter the program name in the search box.
@ChasG:
Have you tried using the Run utility to find and execute applications?Just hit <ALT><F2> and enter the program name in the search box.
A good suggestion but will only work if your program/appimage/script is in the $PATH variable as it does not search for executable files in other locations.
Well, since ChasG has installed his "extra" programs using Synaptic, won't they all be in the $PATH?
yea sorry I was thinking of a different post when I wrote that, I had in mind OP was using appimages or running in userspace.
Hi, what I found a bit confusing is the fact that most of the programs are sorted under the Accessories section. There is where I did not expect to find them.
