#1 2018-10-04 17:18
jim21mex
TTF install in one click
I know that many debian distributions can install TTF fonts in only one click. Why Q4OS it doesn't? When i tried, it's only able to see the font and print it. For what someone (in his right sense) will download a font for only see it?
#2 2018-10-04 22:29
Re: TTF install in one click
I usually copy (or extract zipfile) to the hidden folder (you may need to create this first) ~/.fonts/ and then run the command fc-cache -f -v and the fonts are now "installed" for your user, but if you want them available for all users you could put them in the folder /usr/local/share/fonts/ and then fun the fc-cache command to update them.
I know this is not a "one-click solution" but it is how I have done it for years is easy and reliable.
#3 2018-10-09 03:53
jim21mex
I think windows makes me very lazy... couse I really don't want to use a command line. But I'll try your solution. -anyway, a think that the Q4OS team could implement something for this.
#4 2018-10-09 04:15
jim21mex
Dumb of me... there is a TTF installer in settings/system... sad
#5 2018-10-09 10:24
I was just testing a service menu and noticed you can already install from the right click menu so I guess that is what you also found. smile
#6 2018-10-14 19:31
jim21mex
Well, this could be a closed and solved disscution. wink
