#1 2018-09-30 04:53
DorianDotSlash
Modify apt sources.list(s)
In order to install Steam, Bumblebee and its supporting libs, you must enable the i386 arch.
Doing so gives you harmless warnings/errors as follows;
N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'http://q4os.org/q4repo q4os-3-0-cn InRelease' doesn't support architecture 'i386'
N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'http://q4os.org/qtderepo buster InRelease' doesn't support architecture 'i386'
Modifying the 10_q4os.list and 12_qtde.list files to specify the architecture removes the warning messages.
Example from:
deb http://q4os.org/q4repo q4os-3-0-cn main
to
deb [arch=amd64] http://q4os.org/q4repo q4os-3-0-cn main
It would be great if it was like this out of the box, or if a script modified it after install since the q4os repos don't have i386 packages anyways.
#2 2018-09-30 07:22
Re: Modify apt sources.list(s)
Yes, we are aware about that, however we are going to add the i386 support into the Centaurus repositories in a near future as well. So, the warnings will cease away. You could safely ignore these warnings as long as Centaurus is being a testing release. Thanks for the report.
