#1 2018-09-24 22:57
CaptNoize
Thunderbird Update Issue
I ran a Command Line Update on (dist-upgrade) and in the middle of the update,it said Thunderbird had update issues. It gave me a few selections,but the default was to keep it the same (N) which I did. Now, I can't send any emails. I removed it at Synaptic,and re-installed it, but to no avail...any suggestions...?
#2 2018-09-25 10:59
Re: Thunderbird Update Issue
At first we would suggest you to backup and remove the current user configuration. It should be stored in '$HOME/.thunderbird/' folder, so rename it, run the Thunderbird, make a fresh new configuration and test it. Next, you will need to revert to the original configuration and export, import all your emails.
#3 2018-09-25 19:08
CaptNoize
I completely removed it like you said,re-installed it thru synaptic and now it works...! Thanks Q4OS Team..!
