#1 2016-01-24 11:24
Q4OS Orion 1.4.6 released
http://www.q4os.org/blog.html#news160125
Cool Q4OS wallpapers created by MC included in Basic and Desktop profiles.
#2 2016-01-24 11:27
Re: Q4OS Orion 1.4.6 released
Just a thought, I have to assume that the updates would have been added to a 1.4.4 or 1.4.5 installation during package updates, is that correct?
Dai
#3 2016-01-24 11:36
Yes correct, but there are a few minor features that are not updated automatically.
#4 2016-01-24 12:14
Thank you, is there a way to install these minor features without going through a full installation again?
Dai
#5 2016-01-24 13:26
Running this script in terminal:
$ dash /usr/share/apps/q4os_system/bin/default_desktop_settings.sh
should be sufficient. Note, It will reset all user settings previously made in your profile.
#6 2016-01-24 16:59
bobby
Does this update install the "Desktop Profile Applications" and reset wallpaper, window behavior, etc. ?
No Longer Using Q4OS
#7 2016-01-24 17:01
No, it only reverts desktop settings in user profile. The tool will be described in the Q4OS documentation soon.
#8 2016-01-24 17:03
bobby
That's cool !
Thanks.
#9 2016-01-24 18:49
MC
I ran sudo apt-get update and sudo apt-get dist-upgrade, installed updates, but when I run get-q4os-version it still says 1.4.5-n1.
Am I missing something important about the upgrade?
Q4OS running Xfce
#10 2016-01-24 19:05
You miss nothing. The 'q4os-desktop' package will be pushed into repositories in a few days.
#11 2016-01-24 19:18
MC
OK. Looking forward to it. Thanks for the info.
Q4OS running Xfce
