#1 2016-01-24 06:53
bobby
Can compiler in Q4OS Development pack *.sh to *.x executables ?
Does the Q4OS Development pack include a compiler that I can use to compile bash scripts *.sh to binary executable file that can be placed in /urs/bin and run from command line or by desktop icon ?
For Example: Compile my 4os-update.sh file to /usr/bin/4os-update.x (Termianl --> sudo 4os-update)
Using binary executable files will make sure that no changes have been made to script downloaded from official source.
Thanks for your help,
Bobby
This is what I tried but it failed:
installed shc package & libc6-dev
sudo apt-get install libc6-dev
sudo apt-get install shc
created bash script to run apt-get update --> 4os-update.sh
sudo nano 4os-update.sh
#!/bin/bash
# launch apt-get-update
sudo apt-get update
clear
exit
use shc to try and compile bash shell file to an executable
shc -T -f script.sh
============ERROR========
sh: 1: cc: not found
shc: Success
The C file was created but, the *.x file is missing.
bobby@q4osdev:~/Documents/shcdev$ ls
4os-update.sh  4os-update.sh.x.c
No Longer Using Q4OS
#2 2016-01-24 18:19
Re: Can compiler in Q4OS Development pack *.sh to *.x executables ?
You need to install at least 'gcc' package to be able to compile and link .c files . The best way is to install Q4OS development pack, it includes all the necessary.
#3 2016-01-24 19:37
bobby
Q4OS Team, Thank you - will install Q4OS development pack and try it again.
