Hi community,
the audioplayer autracity and the small-seized videoplayer minitube
were written for ubuntu.
Are they compatible to Q4os as well ? Or can anyone recommend another player with low hardware requirements?
Many thanks for replys in advance!
Minitube is available from Synaptic package manager or you can install with the following command
sudo apt install minitube
I cannot find any reference to a package called Autracity but if you actually mean Audacity then that too is available via Synaptic package manager or the following command in a terminal
sudo apt install audacity
I found smplayer worked well.
