#1 2018-07-28 10:16
jackdanielsesq
Q4OS - Updates - Thunderbird POP3 Corrupt
Greetings All
After a routine update, four of my six POP3 inbox data folders have been corrupted
The rest of the data - sent, drafts, templates, etc, appears to be intact and readable
The other emails are cloud-based, and therefore not impacted
Below are the two files - Java-based ... Ant, Ant-Optional, that were installed recently
Never happened before - have >50GB of email, nary a problem that I could not fix
The various .msf/dat containers are all intact, small in size, as this is a fairly new tranche - [4GB limits]
Have tried all the usual stuff - all to no avail - the other two functioning POP3 inboxes appear normal
Any/all help much appreciated
Regards
Jack
#2 2018-07-28 10:33
Re: Q4OS - Updates - Thunderbird POP3 Corrupt
Please attach files to analyze:
/var/log/apt/history.log
/var/log/apt/term.log
Did anyone else notice the issue ?
