#1 2016-01-23 10:22
Problems with Q4OS uninstallation script.
I have uninstalled Firefox browser using Q4OS uninstallation script. Then I removed /opt/firefox directory and related to Firefox directory in home folder (why script did not removed them?). But for some reasons update manager still offers to update uninstalled Firefox. Also 'apt-cache show firefox' still tells that Firefox is installed (Status: install ok installed).
http://imgur.com/a/dUTZq
Does Q4OS uninstallation script is working properly?
#2 2016-01-23 14:19
Re: Problems with Q4OS uninstallation script.
There could be some dependencies holding Firefox. Try to run in terminal:
$ sudo apt-get autoremove firefox
#3 2016-01-23 20:09
Only 'sudo apt-get autoremove firefox' did not solved problem. Needed to remove firefox-l10n-ru manually. Looks like uninstallation script did not removed localization package. Maybe it is because I used $ sudo ffq4-update previously.
#4 2016-01-23 21:14
Maybe
sudo apt-get --purge remove firefox
would work?
Dai
#5 2016-01-23 21:51
Thank you Dai, but I already solved the problem.
$ sudo apt-get purge firefox-l10n-ru
And that`s all!
This topic can be closed.
Update: Installed Iceweasel 38.5.0 from main repository. Works very good! Flashplugin also works very well.
