#1 2016-01-22 18:47
Theresa
How can I change the musical piece at boot up
One thing I don't much care for is the little drum beat that plays at the end of the boot sequence of q4os. Is there a way to change this to a different musical piece?
#2 2016-01-22 19:39
Re: How can I change the musical piece at boot up
I have the same question. It plays very loud and I always have to readjust my speaker volume every time after boot. Is it possible to disable it?
#3 2016-01-22 23:57
MC
From the menu, go to Settings > Control Panel. Click on Sound & Multimedia. Then click on System Notifications. This is where you can change the start-up music, or turn it off completely.
Scroll through the Events and look for "TDE is starting up".  Click on it to highlight it, then near the bottom, click on Advanced. In the Actions panel, you can change the sound. To turn the sound off completely, clear the check box.
@Theresa: At the moment, there is only one sound file for start-up...the one you want to change is it. There might be some other sound in those files you would like. It looks like Q4OS only supports WAV files. There are three other start-up sound files, but they are .ogg and are not recognized at this time. That might be something for the Q4OS Team's "To-Do" list.
FYI, if you go to /opt/trinity/share/sounds, you will find the other three start sounds (KDE_startup_1, KDE_startup_2, KDE_startup_3). They can be converted to WAV with a sound converter or Audacity.
Q4OS running Xfce
#4 2016-01-23 00:47
MC
I converted the three .ogg files to WAV, but when I tried to attach them it failed. (Too big. sad )
Q4OS running Xfce
#5 2016-01-23 10:27
As I can see, *.ogg sound system notifications are not working at all. Only TDE startup notification is working. Please fix it.
#6 2016-01-23 15:44
Try to permanently set mixer levels with 'alsamixer' or 'alsamixergui' tool.
Yes, bug in Q4OS, will be fixed.
#7 2016-01-23 16:12
You can send it to support@q4os.org , we could make these wavs available in the next Q4OS release. Thank you.
#8 2016-01-23 17:49
MC
Sent.
Q4OS running Xfce
#9 2016-01-23 22:17
Theresa
I can't find /opt/trinity/share/sounds. Can you help please.
#10 2016-01-23 22:35
MC
Hi Theresa. Open your file manager, then above the folder area on the menu bar you will see an UP arrow. Click it twice an you will be in /. There you will see the opt folder. From there, open each of the folder names listed.
Q4OS running Xfce
#11 2016-01-23 22:47
Alternatively you can press Alt+F2 and type:
konqueror /opt/trinity/share/sounds/
and execute
#12 2016-01-25 00:18
Theresa
Thank you. I found the other 3 start sounds.
Theresa
#13 2016-01-25 22:15
Theresa
Sadly more problems. I went to Settings > Control Panel>Sound & Multimedia and double clicked on System Notifications and it opened Firefox! Firefox gave me a dialog box to save file with Kate and the result is real chaos. Screenshot attached. Please help.
#14 2016-01-25 22:18
Theresa
#15 2016-01-25 22:22
Theresa
Sadly more problems. I went to Settings > Control Panel>Sound & Multimedia and double clicked on System Notifications and it opened Firefox! Firefox gave me a dialog box to save file with Kate and the result is real chaos. Has text in other language than English. Unable to attach screenshot. The usual"Error file too big" notification is displayed. Please help.
#16 2016-01-25 22:59
We are not able to reproduce.
Try to run in terminal:
$ tdebuildsycoca
$ kfmclient exec file:/opt/trinity/share/applications/tde/kcmnotify.desktop
$ cat /opt/trinity/share/applications/tde/kcmnotify.desktop
and put terminal output here to analyze
#17 2016-01-26 00:01
Theresa
Here is the terminal output. At the second step above, it opened the normal way with "Configure - TDE Control module"
[tdebuildsycoca] tdebuildsycoca running...
[tdebuildsycoca] Reusing existing tdesycoca.
tdebuildsycoca: WARNING: Parse error in /home/theresa/.config/menus/applications
-merged/xdg-desktop-menu-dummy.menu, line 1, col 1: unexpected end of file
theresa@q4os-desktop:~$ kfmclient exec file:/opt/trinity/share/applications/tde/
kcmnotify.desktop
theresa@q4os-desktop:~$ cat /opt/trinity/share/applications/tde/kcmnotify.deskto
p
[Desktop Entry]
Exec=tdecmshell kcmnotify
Icon=knotify
Type=Application
X-DocPath=kcontrol/kcmnotify/index.html
X-TDE-Library=knotify
X-TDE-ParentApp=kcontrol
Name=System Notifications
Name[af]=Stelsel Inkennistelling
Name[ar]=تنبيهات النظام
Name[az]=Sistem Bildirişləri
Name[be]=Сістэмныя нагадванні
Name[bg]=Уведомяване
Name[bn]=সিসটেম বিজঞপতি
Name[br]=Kemenn ar reizhiad
Name[bs]=Sistemska obavještenja
Name[ca]=Notificacions del sistema
Name[cs]=Systémová hlášení
Name[csb]=Systemòwé dôwanié wiédzë
Name[cy]=Hysbysiadau Cysawd
Name[da]=Systembekendtgørelser
Name[de]=Systemnachrichten
Name[el]=Ειδοποιήσεις συστήματος
Name[eo]=Sistematentigoj
Name[es]=Notificaciones del sistema
Name[et]=Süsteemi märguanded
Name[eu]=Sistemaren jakinarazpenak
Name[fa]=اخطارهای سیستم
Name[fi]=Järjestelmähuomautukset
Name[fr]=Notifications du système
Name[fy]=Systeemoankundigingen
Name[ga]=Fógairt an Chórais
Name[gl]=Notificacións do Sistema
Name[he]=הודעות מערכת
Name[hi]=ततर सचनाए
Name[hr]=Obavijesti sustava
Name[hu]=Rendszerüzenetek
Name[id]=Pemberitahuan Sistem
Name[is]=Kerfistilkynningar
Name[it]=Avvisi di sistema
Name[ja]=システム通知
Name[ka]=სისტემური შეტყობინებები
Name[kk]=Жүйелік құлақтандырулар
Name[km]=ការជនដណងបរពនធ
Name[ko]=시스템 알림
Name[lo]=ການແຈງເຕອນຂອງລະບບ
Name[lt]=Sistemos pranešimai
Name[lv]=Sistēmas Paziņojumi
Name[mk]=Системски известувања
Name[mn]=Системийн сонордуулга
Name[ms]=Pemberitahuan Sistem
Name[mt]=Notifiki tas-Sistema
Name[nb]=Systemvarsler
Name[nds]=Systeemnarichten
Name[ne]=परणाली सचना
Name[nl]=Systeemnotificaties
Name[nn]=Systempåminningar
Name[nso]=Ditsebiso tsa System
Name[oc]=Notificacions dèu sistemo
Name[pa]=ਸਿਸਟਮ ਸਚਨਾਵਾ
Name[pl]=Powiadomienia systemowe
Name[pt]=Mensagens do Sistema
Name[pt_BR]=Notificações do Sistema
Name[ro]=Notificări de sistem
Name[ru]=Системные уведомления
Name[rw]=Amamenyesha Sisitemu
Name[se]=Vuogádatmuittuhusat
Name[sk]=Systémové správy
Name[sl]=Sistemska obvestila
Name[sr]=Системска обавештења
Name[sr@Latn]=Sistemska obaveštenja
Name[sv]=Systemunderrättelser
Name[ta]=அமைபபு குறிபபகள
Name[tg]=Огоҳномаи система
Name[th]=การแจงเตอนของระบบ
Name[tr]=Sistem Bildirimleri
Name[tt]=Sistem Beldermäläre
Name[uk]=Системні повідомлення
Name[uz]=Tizimning xabarnomalari
Name[uz@cyrillic]=Тизимнинг хабарномалари
Name[ven]=Thalutshedzo ya UA (M18 kha WinNT 4.0)
Name[vi]=Thông báo Hệ thống
Name[wa]=Notifiaedjes do sistinme
Name[xh]=Izaziso Zendlela esetyenziswayo
Name[zh_CN]=系统通知
Name[zh_TW]=系統通知
Name[zu]=Izaziso zesistimu
Comment=System Notification Configuration
Comment[af]=Stelsel Inkennisstelling Opstelling
Comment[ar]=إعدادات تنبيهات النظام
Comment[az]=Sistem Bildirişi Quraşdırması
Comment[be]=Настаўленні сістэмных нагадванняў
Comment[bg]=Настройване на системата за уведомяване
Comment[bn]=সিসটেম বিজঞপতি কনফিগারেশন
Comment[br]=Kefluniañ kemenn ar reizhiad
Comment[bs]=Podešavanje sistemskih obavještenja
Comment[ca]=Configuració de les notificacions del sistema
Comment[cs]=Nastavení systémových hlášení
Comment[csb]=Kònfigùracëjô systemòwegò dôwaniô wiédzë
Comment[cy]=Ffurfweddu Hysbysiadau Cysawd
Comment[da]=Opsætning af systembekendtgørelser
Comment[de]=Einstellung der Systemnachrichten
Comment[el]=Ρύθμιση ειδοποιήσεων συστήματος
Comment[eo]=Agordo de sistematentigoj
Comment[es]=Configuración de las notificaciones del sistema
Comment[et]=Süsteemsete märguannete seadistamine
Comment[eu]=Sistemaren jakinarazpenen konfigurazioa
Comment[fa]=پیکربندی اخطارهای سیستم
Comment[fi]=Järjestelmähuomautusten asetukset
Comment[fr]=Configuration du système de notifications
Comment[fy]=Ynstellings fan de systeemoankundigingen
Comment[gl]=Configuración das Notificacións do Sistema
Comment[he]=שינוי הגדרות הודעות המערכת
Comment[hi]=ततर सचना कॉनफ़िगरशन
Comment[hr]=Konfiguriranje obavijesti sustava
Comment[hu]=A rendszerüzenetek beállítása
Comment[id]=Konfigurasi pemberitahuan sistem
Comment[is]=Stillingar tilkynninga frá kerfinu
Comment[it]=Configurazione degli avvisi di sistema
Comment[ja]=システム通知の設定
Comment[ka]=სისტემური შეტყობინებების კონფიგურაცია
Comment[kk]=Жүйелік құлақтандыруларды баптау
Comment[km]=ការកណតរចនាសមពនធជនដណងបរពនធ
Comment[ko]=시스템 알림 설정
Comment[lo]=ປບແຕງການແຈງເຕອນຂອງລະບບ
Comment[lt]=Sistemos pranešimų derinimas
Comment[lv]=Sistēmas Paziņojumu Konfigurēšana
Comment[mk]=Конфигурација на системските известувања
Comment[mn]=Системийн сонордуулга тохируулга
Comment[ms]=Konfigurasi Pemberitahuan Sistem
Comment[mt]=Konfigurazzjoni tan-notifiki tas-Sistema
Comment[nb]=Oppett av systemvarsling
Comment[nds]=Systeemnarichten instellen
Comment[ne]=परणाली सचना कनफिगरसन
Comment[nl]=Instellingen van de systeemnotificatie
Comment[nn]=Oppsett av systempåminningar
Comment[nso]=Peakanyo ya Tsebiso ya System
Comment[oc]=Configuracion de les notificacions dèu sistemo
Comment[pa]=ਸਿਸਟਮ ਸਚਨਾ ਸਰਚਨਾ
Comment[pl]=Konfiguracja powiadamiania systemowego
Comment[pt]=Configuração das mensagens do sistema
Comment[pt_BR]=Configuração das notificações do sistema
Comment[ro]=Configurează notificările de sistem
Comment[ru]=Настройка системных уведомлений
Comment[rw]=Iboneza ry'Amamenyesha Sisitemu
Comment[se]=Heivet vuogádatmuittuhusat
Comment[sk]=Nastavenie správ systému
Comment[sl]=Nastavitev sistemskih obvestil
Comment[sr]=Подешавање системских обавештења
Comment[sr@Latn]=Podešavanje sistemskih obaveštenja
Comment[sv]=Anpassa systemunderrättelser
Comment[ta]=சாதனம குறிபபு அமைபபு
Comment[tg]=Танзими огоҳномаи система
Comment[th]=ปรบแตงการแจงเตอนของระบบ
Comment[tr]=Sistem Bildirimi Yapılandırması
Comment[tt]=Sistem Beldermälären Caylaw
Comment[uk]=Налаштування системних повідомлень
Comment[uz]=Tizimning xabarnomalarini moslash
Comment[uz@cyrillic]=Тизимнинг хабарномаларини мослаш
Comment[ven]=Khonifiguresheni yau divhadza sisiteme
Comment[vi]=Cấu hình Thông báo Hệ thống
Comment[wa]=Apontiaedje po les notifiaedjes do sistinme
Comment[xh]=Uqwalaselo Lwezaziso Zendlela yokusebenza
Comment[zh_CN]=系统通知配置
Comment[zh_TW]=系統通知組態
Comment[zu]=Inhlanganiselo yokwazisa kwesistimu
Keywords=System sounds;Audio;Sound;Notify;Alerts;Notification;
Keywords[af]=Stelsel sounds;Audio;Sound;Notify;Alerts;Notification;
Keywords[ar]=أصوات النظام;Audio;System sounds;Audio;Sound;Notify;Alerts; Notific
ation;صوت;نبه;تحذيات;تنبيهات;
Keywords[az]=Sistem səsləri;Səs;Bildir;Alarmlar;Bildirmə;
Keywords[be]=Сістэмныя гукі;Аўдыё;Гук;Нагадванне;Важныя нагадванні;Нагадваць;Sys
Keywords[bg]=системен; звук; уведомяване; информация; грешка; събития; System so
unds; Audio; Sound; Notify; Alerts; Notification;
Keywords[br]=sonioù ar reizhiad;klevet;son;kemenn;evezh;
Keywords[bs]=System sounds;Audio;Sound;Notify;Alerts;Notification;zvuk;
Keywords[ca]=Sons del sistema;Àudio;So;Notifica;Alertes;Notificació;
Keywords[cs]=Systémové zvuky;Audio;Oznámit;Varování;Oznámení;
Keywords[csb]=Systemòwé zwãczi;Audio;Zwãk;Dôwac wiédzã;Alarmë;Dôwanié wiédzë;
Keywords[cy]=Sain cysawd;Awdio;Swn;Hysbysu;Rhybuddion;Hysbysiad;
Keywords[da]=Systemlyde;audio;Lyd;Bekendtgør;Advarsler;Bekendtgørelse;
Keywords[de]=Klänge;Systemklänge;Audio;Sound;Benachrichtigung;Nachricht;Alarm;Si
gnalton;Beep;
Keywords[el]=Ήχοι συστήματος;Audio;Ήχος;Ειδοποιώ;Συναγερμοί;Ειδοποίηση;
Keywords[eo]=sistemo;sonoroj;aŭdio;sono;atentigo;alarmo;operaciumo;
Keywords[es]=Sonidos del sistema;Audio;Sonido;Notificar;Alertas;Notificación;
Keywords[et]=süsteemsed helid;audio;heli;märguanded;alarm;
Keywords[eu]=Sistemaren soinuak;Audioa;Soinua;Jakinarazi;Alertak;Jakinarazpenak;
Keywords[fa]=صداهای سیستم، صوتی، صوت، اخطار، هشدار، اخطار;
Keywords[fi]=Järjestelmä-äänet;Äänet;Huomauttaa;Varoitukset;Huomautus;
Keywords[fr]=sons du système;son;audio;notification;alertes;événements;
Keywords[fy]=systeemlûden;audio;lûd;warskôgingen;lûdssinjaal;oankundiging;
Keywords[gl]=Sons do sistema;Audio;Son;Notificar;Alertas;Notificación;
Keywords[he]=צלילי מערכת;שמע;צליל;הודעה;תזכורות; System sounds;Audio;Sound;Notif
Keywords[hi]=ततर धवनि;ऑडियो;धवनि;सचना;सतरक;सचनाए;
Keywords[hr]=System sounds;Audio;Sound;Notify;Alerts;Notification;Zvuk;Sistemski
zvukovi;Obavijesti;Upozorenja;Obavijest;
Keywords[hu]=rendszerhangok;audió;hang;figyelmeztető;vészjelző;
Keywords[id]=System sounds;Audio;Sound;Notify;Alerts;Pemberitahuan;
Keywords[is]=Kerfishljóð;Hljóð;Tilkynningar;Villur;Bjalla;
Keywords[it]=Suoni di sistema;Audio;Suono;Notifica;Avvisi;Messaggi;
Keywords[ja]=システムサウンド;オーディオ;サウンド;通知; アラート;通知;
Keywords[ka]=სისტემის ხმები;აუდიო;ხმა;შეტყობინება;განგაში;შეტყობინება;
Keywords[km]=សឡេងបរពនធ;សឡេង;សោត;ជនដណង;ពរមាន;ការជនដណង;
Keywords[lt]=Sistemos garsai;Audio;Garsas;Pranešimas;Perspėjimai;
Keywords[lv]=Sistēmas skaņas;Audio;Skaņa;Paziņo;Brīdinājumi;Paziņošana;
Keywords[mk]=System sounds;Audio;Sound;Notify;Alerts;Notification;Системски звуц
и;Аудио;Звук;Извести;Предупредувања;Известувања;
Keywords[mn]=Чимээ;Системийн чимээ;Audio;Дуу;Мэдээлэгч;Мэдээ;Alarm;Сигналын чимэ
э;Beep;
Keywords[nb]=Systemlyder;Lyd;Varsle;Advarsel;Varsling;alarm;signal;
Keywords[nds]=Systeemkläng;Audio;Klang;Notify;Bescheed;Notification;Bescheed gev
en;
Keywords[ne]=परणाली धवनि; अडियो; धवनि; सचित; चतावनी; सचना;
Keywords[nl]=systeemgeluiden;audio;geluid;waarschuwingen;geluidssignaal;notifica
tie;
Keywords[nn]=systemlydar;lyd;påminning;varsel;alarm;signal;
Keywords[nso]=Medumo ya System;Kwagalo;Modumo;Tsebisa;Ditheeletso;Tsebiso;
Keywords[oc]=Sons dèu sistemo;Ã?udio;Son;Notifica;Alertes;Notificacion;
Keywords[pa]=ਸਿਸਟਮ ਧਨੀ;ਆਡੀਓ;ਧਨੀ;ਸਚਨਾ;ਚਤਾਵਨੀ;ਸਚਨਾਵਾ;
Keywords[pl]=Dźwieki systemowe;Audio;Dźwiek;Powiadamiac;Alarmy;Powiadamianie;
Keywords[pt]=sons de sistema;áudio;som;notificar;alertas;notificação;
Keywords[pt_BR]=Sons de sistema;áudio;Som;Notificação;Alertas;Notificação;
Keywords[ro]=sunete de sistem;audio;sunet;alertă;notificare;
Keywords[rw]=Amajwi sisitemu;Inyumvo;Ijwi;Kumenyesha;Integuza;Imenyekanisha;
Keywords[se]=vuogádatjienat;jietna;audio;dieđihit;váruhusat;signála;
Keywords[sk]=Systém zvukov;Audio;Zvuk;Správy;Upozornenia;
Keywords[sl]=sistemski zvoki;avdio;zvok;obvestila;alarmi;
Keywords[sr]=System sounds;Аудио;Sound;Notify;Alerts;Notification;Звук;Узбуне;об
авештења;системски звуци;
Keywords[sr@Latn]=System sounds;Audio;Sound;Notify;Alerts;Notification;Zvuk;Uzbu    ne;obaveštenja;sistemski zvuci;
Keywords[sv]=Systemljud;Ljud;ljud;Underrättelse;Varningar;Bekräftelse;
Keywords[ta]=அமைபபு ஒலிகள;கேடபொலி;ஒலி;தெரியபபடுதது;எசசரிககைகள;தெரியபபடுததுதல;
Keywords[th]=ระบบเสยง;ออดโอ;เสยง;แจงเตอน;เตอน;การแจงเตอน;
Keywords[tr]=Sistem sesleri;Ses;Bildir;Alarmlar;Bildirme;
Keywords[uk]=системні звуки;аудіо;audio;звук;повідомлення;попередження;сповіщенн    я;
Keywords[uz]=Tizim tovush signallari;Audio;Tovush;Xabar berish;Xabarnomalar;
Keywords[uz@cyrillic]=Тизим товуш сигналлари;Аудио;Товуш;Хабар бериш;Хабарномала    р;
Keywords[ven]=Mubvumo wa sisitemu;Zwaupfiwa;Mubvumo;Divhadza;Divhisa;Ndivhadzo;
Keywords[vi]=Âm thanh hệ thống;Âm;Âm thanh;Thông báo;Cảnh báo;Thông báo;
Keywords[wa]=Sons do sistinme;Audio;Son;Notifyî;Alertes;Notifiaedje;
Keywords[xh]=Izandi zendlela;Evakalayo;Isandi;Yazisa;Izilumkiso zengozi;Izaziso;
Keywords[zh_CN]=System sounds;Audio;Sound;Notify;Alerts;Notification;系统音效;音    效;通知;警报;
Keywords[zh_TW]=System sounds;Audio;Sound;Notify;Alerts;Notification;系統音效;音    效;通知;警報;
Keywords[zu]=Imisindo yesistimu;Okuzwakalayo;Umsindo;Yazisa;Ukuqwashisa; Ukwazis    a;
Categories=Qt;TDE;X-TDE-settings-sound;
#18 2016-01-26 16:58
Everything looks fine. Try to reset your desktop settings, note it will revert changes you have made in your user profile:
$ dash /usr/share/apps/q4os_system/bin/default_desktop_settings.sh
#19 2016-01-26 18:22
Theresa, please use postimage.org for posting your screenshots. Or imgur.com.
#20 2016-01-26 18:32
Theresa
The desktop was reset to default. I could see the changes. The issue is still there. I learned to take smaller screenshots and I am attaching 2. Attachment in this post shows what happens when I click on System Notifications - Firefox opens and prompts me to open program with Kate. The one in the next post below shows the result after Kate opened System notifications.
Theresa
#21 2016-01-26 18:33
Theresa
Kate opens System notifications. (Is it possible to include more than one attachment in a post?)
#22 2016-01-26 19:05
Something similar is happening, when I try to 'Open in new window'.
http://postimg.org/image/qs8cm7nov/
http://postimg.org/image/oc6j8d5m7/
With mouse double-click all opens as it should be.
http://postimg.org/image/6pyo3kxin/
Try to launch Control Centre --> Peripherals --> Mouse and revert default mouse settings.
#23 2016-01-26 20:00
Theresa
I got as far as Mouse and couldn't find the default settings for it. When I double clicked on the mouse icon, the same thing that happened when I double clicked on system notifications happened. The same as in the attachments I have posted above. Firefox opened and all the rest.
I also found this. Right clicked on mouse icon>properties>in the little window that opens I clicked on the spanner next to Mouse settings. The window that opened shows Firefox as "Application preference order". I have attached it here.
Then I right clicked System notifications>Properties>System notification configuration (spanner tool), and got the exact result = An identical window to  what I got above with the Mouse. Application preference order - Firefox. The window is identical in both cases.
I wonder if all this is important to my problem.
Theresa
#24 2016-01-26 20:26
Looks like you found the solution! Remove Firefox from Application preference order. I don`t have any applications defined there.
http://itmages.ru/image/view/3566709/1de6a27a
http://storage5.static.itmages.ru/i/16/ … a27a6a.png
#25 2016-01-26 20:31
The last post shows the problem, your system has messed file associations. It could happen by manual intervention or by some automatic process. Where did you install Firefox from ?
Click on the 'Firefox' in 'Application preference order' and remove it with 'Remove' button. Save and try to open Control panel items again.
Update: Oh, Rademes was faster, as I see above smile
Probably not related to Theresa's issue, looks rather like a Trinity bug.
