#1 2018-05-07 09:05
chiguy1256
VirtualBox Shared Folders
I have Q4OS installed as a VirtualBox guest on a Windows 10 host.  I have added a shared folder to the Q4OS virtual machine.  How do I access this shared folder on Q4OS?  Thanks.
#2 2018-05-07 10:28
Re: VirtualBox Shared Folders
You need to run in terminal:
$ sudo mkdir /mnt/vboxdir
$ sudo mount -t vboxsf shared_folder_name /mnt/vboxdir
If you want to mount it permanently, add the following line to the '/etc/fstab/ file:
shared_folder_name /mnt/vboxdir1 vboxsf defaults,noauto 0 0
#3 2018-05-07 11:37
chris_elvidge
First make sure "shared_folder" is permanent : auto-mount "yes", access "full".
Start virtual machine.
"shared_folder" should now be mounted under /media/sf_shared_folder, user root and group vboxsf.
Make sure YOU are a member of group vboxsf to obtain full access.
#4 2018-05-15 02:21
chiguy1256
Thank you Q4OS Team and chris_elvidge.  I will give it a try.  Wish me luck.  smile
#5 2018-06-09 00:31
chiguy1256
Okay, I am able to mount the Windows shared folder.  However, I did add to the /etc/fstab, but it won't mount permanently.  Here is a copy of my fstab. I am sure I probably made an error.  Please advise.  Thanks.
fstab
#6 2018-06-09 14:58
chris_elvidge
Is your shared folder really called "Windows_share"? Try without "noauto". Noauto stops automatic mount.
You really don't need an entry in fstab to make this work. "Windows_share" should mount automatically at "/media/sf_Windows_share"
#7 2018-06-15 01:02
chiguy1256
Never mind.  It seems to be working fine now.  Thank you.
