#1 2015-12-22 10:04
Panel for adding applicationd is bugged, cannot edit Q4OS start menu
I tried to Add new panel -> Panel for adding applications. But I have been waiting for 5 minutes and panel still has not added. Even reboot did not helped at all.
Only white empty place was shown instead of new panel.
http://imgur.com/a/jiiad
Also Xfburn does not have icon installed.
Also, editing default Q4OS start menu using menu editor does not working. Need to switch to TDE menu to be able to edit it. Please fix it, because it is very important to be able to edit start menu.
#2 2015-12-22 12:02
Re: Panel for adding applicationd is bugged, cannot edit Q4OS start menu
I tried to Add new panel -> Panel for adding applications. But I have been waiting for 5 minutes and panel still has not added. Even reboot did not helped at all. Only white empty place was shown instead of new panel.
Yes, reproducible Trinity bug, you could report at https://bugs.trinitydesktop.org/buglist … search=ALL
Yes, missing 'media-cdrom' icon in 'crystalsvg' icon set. You could report at https://bugs.trinitydesktop.org/buglist … search=ALL
Editing default Q4OS start menu using menu editor does not working.
Please see http://www.q4os.org/dqa011.html#desktop.2
#3 2016-01-22 18:29
After reporting bug, Slavek Banko has written a comment and changed bug status to NEEDINFO. Something about making media-cdrom and media-optical as a symlink to the media-optical-cdrom. What should I answer him?
Bug 2577 fixed. Haven`t checked yet.
#4 2016-01-23 16:06
We would wait for TDE devs to fix it, but it must not be a TDE bug, as they said 'media-cdrom' is out of XDG specification.
