#1 2018-06-08 12:50
witloof
installation of chalk-trinity
Q4OS Centaurus 3.2 -- fully updated
When trying to install chalk-trinity I get the following message:
copy & paste:
chalk-trinity:
Depends: koffice-libs-trinity but it is not going to be installed
Depends: liblcms1 but it is not going to be installed
Depends: libpoppler-tqt but it is not going to be installed
Depends: libpoppler73 (>=0.62.0) but it is not installable
Depends: chalk-data-trinity but it is not going to be installed
Recommends: dcraw but it is not going to be installed
This is where I stopped.
Thanks
#2 2018-06-08 19:10
Re: installation of chalk-trinity
Yes, we can confirm chalk-trinity has broken dependencies in Debian Buster. thanks for reporting.
#3 2018-06-10 08:19
witloof
My pleasure !
#4 2018-06-11 04:12
witloof
I installed today the ' new ' download of chalk-trinity.
>>>>>EDIT: Maybe not an install, but only update ! ! !
The installation goes normal, but.......when going to/graphics/chalk and clicking....nothing happens.
When placing the icon on the desktop and clicking, it says :
TDEInit could not launch 'chalk'.:
Could not find 'chalk' executable.
Have done a reboot...same.
witloof
#5 2018-06-11 10:54
witloof
!!!! Don't know what happened, or what I did !!!!! but I just checked something in Synaptic and saw that chalk-data-trinity was installed  but not..chalk-trinity
I uninstalled chalk-data-trinity , rebooted, reload synaptic and installed again.
Same message as above and nothing installed
#6 2018-06-11 12:05
I imagine it has not been installed due to the "unmet dependencies" issue you encountered on your initial installation.
You may have installed chalk-data-trinity separately which is why it is showing as installed.
Until the dependency issue is sorted out any attempts to install it will fail (unless you "force" the installation [NOT recommended]), and I just checked with Synaptic and it will not install but will show you the output from your initial post regarding the dependency issue.
