#1 2018-05-21 02:30
servimo
q4os on a virtual box machine
I installed q4os-3.2 on a virtual box machine and after this it asked me to install virtualbox guest addiction packages, I accept, but my monitor is 1920x1080, but it din't resize to this resolution. The window stays at 1024x768
#2 2018-05-21 07:46
Re: q4os on a virtual box machine
You may need to update your system, run in terminal:
$ sudo apt update ; sudo apt dist-upgrade
and reboot.
#3 2018-05-21 23:42
servimo
I uninstalled and then reinstalled vbox guest addictions from q4os and here is what I get in dkms make.log in the attachament.
Doing an update doesn't solved
