#1 2018-05-15 04:18
Akira Kazama
Q4OS 64-bit doesn't load the desktop, Q4OS 32-bit works fine.
I have tried to install Q4OS 2.4 64-bit from the live CD but after loading it just showed a tty1 command line.
I thought the CD could be badly burned, so I downloaded Q4OS 2.4 64-bit again, but this time I downloaded the installation CD, the system was installed without problems but after the first boot, it just showed a tty1 command line asking for my username and password.
Q4OS 2.4 32-bit and other 64-bit distributions work fine but I want to install Q4OS 64-bit. Any help please?
Hardware:
PC: Compaq Presario SG3303LA
CPU: Intel Celeron 220
RAM: 2 GB DDR2 800 MHz
Motherboard: Foxconn LIMA
GPU: Intel 82945G/GZ
#2 2018-05-15 09:26
VolodVer
Re: Q4OS 64-bit doesn't load the desktop, Q4OS 32-bit works fine.
#3 2018-05-15 09:38
You most likely need to install Intel video driver, run in terminal:
$ sudo apt install xserver-xorg-video-intel
and reboot.
#4 2018-05-18 04:49
Akira Kazama
It worked, thank you so much for your help.
