#1 2018-05-14 18:43
linuxmel
Installer
I've downloaded the iso, not booted up yet. Is the installer method GUI based?
Thanks so much in advance.
#2 2018-05-14 19:18
Re: Installer
It depends which image you have downloaded, The Live-cd will give you a Live Desktop session and the installer is a GUI one, the installer only image will give you a text based installer and as such is console based. I prefer to always use the Live-Cd as it is a good way to check the OS will work on your machine, any problems you encounter in a live session will likely continue to a full installation, and on the flip side if the live session works well then it is very likely you will encounter no further problems with a full installation.
Of course if you are using a Raspberry Pi image then there is no installation to perform as such, but if that is the case I imagine you would be familiar with creating a file-system onto Sd cards.
And welcome to the Forum smile
#3 2018-05-14 19:21
Re: Installer
There are two types of Q4OS installation media available to download. If you downloaded the 'live-cd' iso the installer is gui based, unlike 'install-cd', which contains text based installer only.
EDIT:
While typing a more detailed answer has been posted, thanks Dai_trying smile
#4 2018-05-14 19:24
Re: Installer
big_smile beat you by three minutes big_smile
#5 2018-05-14 19:24
Re: Installer
smile
#6 2018-05-14 19:38
linuxmel
Re: Installer
Thanks for the great explanation, and thank you for the welcome!
