#1 2015-12-09 23:26
Ghost692000
Obtaining Applets
Would anyone know where I can get more Applets or specificity a CPU Thermal monitor. My laptop has a tendency to get hot and I like to keep a check on it. I installed "psensor", just having a problem getting it on the task bar.
#2 2015-12-10 21:20
Re: Obtaining Applets
You could try to install ksensors-trinity in terminal:
$ sudo apt-get install ksensors-trinity
#3 2015-12-14 02:44
Ghost692000
Synaptic is the 2nd thing I install after the 1st update. Just didn't think of ksensor. I got a cooler master cooling pad that has a butt load of fans in it. I just like to see what temps are. Thanks for the help guys.
