#1 2018-05-03 22:07
pkexec not working as expected
I am currently re-writing my apt updater/notifier and have found some strange behaviour when using the pkexec command, I can see it is aliased to tdesudo which is causing a small issue and although it is not a critical problem it does cause me to include some workaround code to account for it.
The problem is I can use the command
sudo apt-get -q update
to update the repositories, but if I use the command
pkexec apt-get -q update
I get the following error
dai@q4scorpion:~$ pkexec apt-get -q update
tdesudo: Unknown option '-q'.
tdesudo: Use --help to get a list of available command line options.
I can use this command on a standard debian installation without issue due to the pkexec command being used natively. The reason I wanted to use pkexec is to have a secure method of elevating privileges that is not distro specific and as pkexec is available I thought it would be a good fit.
I have tried sourcing pkexec directly from /usr/bin with
/usr/bin/pkexec apt-get -q update
which gives the following error
dai@q4scorpion:~$ /usr/bin/pkexec apt-get -q update
==== AUTHENTICATING FOR org.freedesktop.policykit.exec ===
Authentication is needed to run `/usr/bin/apt-get' as the super user
Authenticating as: dai,,, (dai)
Password:
polkit-agent-helper-1: error response to PolicyKit daemon: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: No session for cookie
==== AUTHENTICATION FAILED ===
Error executing command as another user: Not authorized
This incident has been reported.
Obviously I have sudo rights on this desktop but it seems policykit might not be set-up correctly, any advice? smile or is this maybe a bug?
#2 2018-05-04 07:55
Re: pkexec not working as expected
Dai_trying wrote:
...I can see it is aliased to tdesudo which is causing a small issue and although it is not a critical problem it does cause me to include some workaround code to account for it. ...
Yes, we can confirm an incorrect implementation of the pkexec aliasing in Q4OS. It will be fixed by the next 'q4os-base' update. Meanwhile, you can safely fix the '/opt/trinity/bin/pkexec' file to be:
#!/bin/sh
#for pkexec the 'polkit-gnome-authentication-agent-1' daemon have to be launched
ARGS="$( echo "$@" | sed "s/--user/-u/g" )"
tdesudo "$ARGS"
which gives the following error ...
... but it seems policykit might not be set-up correctly, any advice? smile or is this maybe a bug?
You need to run pkexec from a gui terminal to be proceeded correctly, as it needs 'polkit-gnome-authentication-agent-1' daemon to be loaded within the current session. It works the same way in the bare Debian system, as well as in Q4OS.
#3 2018-05-04 08:11
#!/bin/sh
tdesudo "$ARGS"
Thank you, this fixed the problem for me. smile
