#1 2018-04-20 06:39
Problem with the way Q4OS names are returned in grub menu - Orion
If you have multiple kernels installed - or indeed if you just want the opportunity to choose how you boot the one kernel then you have a problem.
Normally grub will provide the kernel name and 3 options for booting it.
With Q4OS all you get is 3 lines the same.
With 2 kernels you get 6 lines all the same
Presumably this is from the variables in the GRUB_DISTRIBUTOR line?
#2 2018-04-20 06:52
Re: Problem with the way Q4OS names are returned in grub menu - Orion
Yes, we can confirm this glitch. You need to update '/etc/grub.d/10_linux' file, change the line:
version="$q4osversion"
to be:
version="$2"
and run:
$ sudo update-grub
#3 2018-04-20 06:55
Excellent - thanks for confirming the syntax.
#4 2018-04-20 07:20
#5 2018-04-20 07:23
We will fix this issue within the next Q4OS Scorpion release, thanks for reporting.
