#1 2017-11-03 12:49
Palemoon installer, even nonSSE version available
We have compiled new Palemoon installer, you can download it here https://sourceforge.net/projects/q4os/f … erimental/
Additionally, you can install a nonSSE Palemoon version:
$ sudo dpkg --add-architecture i386
$ sudo apt update
$ sudo apt install palemoon-nonsse2
#2 2017-11-03 19:48
Re: Palemoon installer, even nonSSE version available
People with older systems will really benefit from this.
#3 2017-11-04 07:39
Interesting - I'm currently playing with an elderly 1.7Ghz Celeron M Sony Vaio 1gb RAM. Using
I have Palemoon on there along with Midori - will give the nonSSE version a whirl.
Thanks team!
#4 2017-11-04 17:50
1.7 celeron M 390 supports MMX,SSE,SSE2 to my knowledge.
#5 2017-11-05 06:42
It definitely should, yes.
#6 2017-11-05 06:56
Absolutely, but just looking for any possible edge. Midori still feels a bit lighter.....
#7 2017-11-05 17:52
Midori is lighter no doubt and I use it mainly on my older slower systems but it has compatibility issues with some websites and graphical issues at times.
#8 2018-04-10 22:53
Flashhh
Is there still online the Plemoon non see version? I type
alberto@q4os-desktop:~$ sudo apt-get update
Obj:1 http://security.debian.org/debian-security stretch/updates InRelease
Ign:2 http://ftp.debian.org/debian stretch InRelease
Obj:3 http://q4os.org/q4repo q4os-2-0-cn InRelease
Obj:4 http://q4os.org/qtderepo stretch InRelease
Obj:5 http://q4os.org/qextrepo stretch-libreoffice-cn InRelease
Obj:6 http://ftp.debian.org/debian stretch-updates InRelease
Obj:7 http://ftp.debian.org/debian stretch Release
Leyendo lista de paquetes... Hecho
alberto@q4os-desktop:~$ sudo apt-get install palemoon-nonsse
Creando árbol de dependencias
Leyendo la información de estado... Hecho
E: No se ha podido localizar el paquete palemoon-nonsse
Dont find the Palemoon Noon See2
#9 2018-04-10 23:13
Yes, you only need to install Palemoon first, download installer from here https://sourceforge.net/projects/q4os/f … erimental/
$ sudo apt update
#10 2018-04-10 23:36
Flashhh
$ sudo apt update
Im still getting the same "cant find palemoon-nonsee2" :
alberto@q4os-desktop:~$ sudo dpkg --add-architecture i386
alberto@q4os-desktop:~$ sudo apt update
[sudo] password for alberto:
Obj:3 http://ftp.debian.org/debian stretch-updates InRelease
Obj:4 http://ftp.debian.org/debian stretch Release
Obj:6 http://q4os.org/q4repo q4os-2-0-cn InRelease
Obj:7 http://q4os.org/qtderepo stretch InRelease
Obj:8 http://q4os.org/qextrepo stretch-libreoffice-cn InRelease
Todos los paquetes están actualizados.
alberto@q4os-desktop:~$ sudo apt install palemoon-nonsse2
E: No se ha podido localizar el paquete palemoon-nonsse2
I also download installer and install Palemoon from there, I can see Palemoon in the list of Aplications--Accesories--Internet---Palemoon Web Browser , but when I hit on the icon Palemoon dont open (may be because the version that the installer download is SSE2 not SSE
#11 2018-04-10 23:50
You need to install Palemoon using downloaded installer first. Afterwards, proceed the steps specified:
$ sudo apt update
#12 2018-04-11 00:25
Flashhh
$ sudo apt update
Yes sir! I did that! but I still getting the same "cant find palemoon-nonsee2"
Let me say the steps how I installed Palemon from the Installer and then try to install palemoon nonsee2:
1) I download the installer from here:
http://linux.palemoon.org/download/installer/
2) alberto@q4os-desktop:~$ /home/alberto/Documentos/Palemoon/pminstaller.sh
3) Ask me for password and I typed it (admin password for installation)
4) A warning appear "Palemoon requires a processor that supports the SEE2 instruction set"
5) I press OK to that warning
6) After press the Ok of step 5),  I see the menu under the welcome installer  "Welcome to the Pale Moon for Linux Installer"
7) I press "Install Palemon" from that menu
8) Palemoon installed ok
9) I verified that Palemon was installed under aplicattions and I start with this:
$ sudo apt update
10) and this was the result:
I also repeat all the steps and the installer said that another version of Palemoon was installed.... so I didnt installed it again but I typed again
$ sudo apt update
and the answer was the same "cant find the palemoon-noonsse2 pakage" (E: No se ha podido localizar el paquete palemoon-nonsse2)
#13 2018-04-11 07:23
You need to install Palemoon using Q4OS installer, as posted above:
Please do not install using installer from here:
$ sudo apt update
#14 2018-04-25 02:14
Flashhh
$ sudo apt update
Thank you very much!!. Sorry for my delay in the answer. Whats a difference using Palemoon instead of the deafault browser!! Palemoon is exelent, I think it should be the default browser in Q4OS for Non SSE2 micros.
#15 2018-09-16 03:27
gain
I installed 2.6 scorpions.
Is the "palemoon-nonsse2" package lost from the repository?
After installing PALEMOON from the .esh file, even if you follow the instructions, you will be told that "Package is missing or obsolete" and you will get a message saying "It will be replaced with palemoon or palemoon:amd64".
After that there was no palemoon-nonsse2 in the "E:" message
