#1 2018-04-07 15:07
Flashhh
Cant return to 1280x1024 video resolution after installing Nvidia Driv
Hello. May be is a basic answer (Im new on linux, I only have more than 25 years of Windows). After installed Q4OS I have the right resolution of 1280x1024, but a notice after installation said that I should download and Install Nvidia drivers. After download and install Nvidia drivers the resolution changed to 640x480 and I have no options under PC Confiiguration or Nvidia Configuration to return to 1280x1024 (the best resolution under config is 640x480). I read a lot on forums and try some commands lines trying to change xorg config without  any good results. How can I solve this?
The video card is a gforce 6200 with 256mb ram. The Pc is old, an Athlon XP 2400 (no SSE2) with 2GB RAM DDR 400.
Regards
#2 2018-04-11 08:16
Re: Cant return to 1280x1024 video resolution after installing Nvidia Driv
You may want to reset the video settings using terminal command below:
$ sudo vd-reset
This command will backup and remove the 'xorg.conf' file generated by Nvidia setup, and reset Xorg video system to its default configuration.
