#1 2018-04-05 18:19
Flashhh
Cant download Spanish Language package
Hello. Im a new user of Q4os. Looks great!. I have a problem, I cant download Spanish language package because said "Unable to download, check internet connection please. You can easily install language pack later, using a desktop icon". I have a good internet connection, desktop installer can download anything the priblem is with Language package. How can I solve this?
Regards
#2 2018-04-05 18:32
Re: Cant download Spanish Language package
Please run terminal from the start menu, issue the following command:
dash $HOME/.addlang_ai_01.sh
and post back the terminal output here to analyze.
#3 2018-04-05 19:23
Flashhh
Thanks for your answer. Here is the output:
alberto@q4os-desktop:~$ dash $HOME/.addlang_ai_01.sh
TDE_Code: es ; Language: Spanish ; ok.
Downloading packages file ...
Download failed, check Internet connection, exiting ...
unable to download, exiting ...
#4 2018-04-05 19:41
Well, let's start digging, please run in terminal:
SYSARCH="$( dpkg --print-architecture )"
QAPTDISTR_A="$( dash /usr/share/apps/q4os_system/bin/print_qaptdistr.sh )"
echo "Arch - $SYSARCH"
echo "Distro - $QAPTDISTR_A"
WDIR1="http://www.q4os.org/qtderepo/"
WDIR2="dists/$QAPTDISTR_A/main/binary-$SYSARCH/"
wget -T70 -t2 --progress=dot $WDIR1/$WDIR2/Packages
and post back.
#5 2018-04-05 21:44
Flashhh
alberto@q4os-desktop:~$ QAPTDISTR_A="$( dash /usr/share/apps/q4os_system/bin/print_qaptdistr.sh )"
alberto@q4os-desktop:~$ echo "Arch - $SYSARCH"
Arch - i386
alberto@q4os-desktop:~$ echo "Distro - $QAPTDISTR_A"
Distro - stretch
alberto@q4os-desktop:~$ WDIR1="http://www.q4os.org/qtderepo/"
alberto@q4os-desktop:~$ WDIR2="dists/$QAPTDISTR_A/main/binary-$SYSARCH/"
alberto@q4os-desktop:~$ wget -T70 -t2 --progress=dot $WDIR1/$WDIR2/Packages
--2018-04-05 17:43:07--  http://www.q4os.org/qtderepo//dists/str … //Packages
Resolviendo www.q4os.org (www.q4os.org)... 81.95.96.231, 2a02:4a8:ac24:108::96:231
Conectando con www.q4os.org (www.q4os.org)[81.95.96.231]:80... conectado.
Petición HTTP enviada, esperando respuesta... 200 OK
Longitud: 1127063 (1,1M)
Grabando a: “Packages”
     0K .......... .......... .......... .......... ..........  4% 81,5K 13s
    50K .......... .......... .......... .......... ..........  9% 78,9K 12s
   100K .......... .......... .......... .......... .......... 13%  142K 10s
   150K .......... .......... .......... .......... .......... 18% 44,6K 12s
   200K .......... .......... .......... .......... .......... 22% 32,2K 15s
   250K .......... .......... .......... .......... .......... 27% 94,6M 11s
   300K .......... .......... .......... .......... .......... 31%  164K 10s
   350K .......... .......... .......... .......... .......... 36%  177K 9s
   400K .......... .......... .......... .......... .......... 40%  184K 7s
   450K .......... .......... .......... .......... .......... 45%  179K 7s
   500K .......... .......... .......... .......... .......... 49% 74,4K 6s
   550K .......... .......... .......... .......... .......... 54%  754K 5s
   600K .......... .......... .......... .......... .......... 59%  111K 5s
   650K .......... .......... .......... .......... .......... 63%  112K 4s
   700K .......... .......... .......... .......... .......... 68% 91,4K 4s
   750K .......... .......... .......... .......... .......... 72%  171K 3s
   800K .......... .......... .......... .......... .......... 77%  257K 2s
   850K .......... .......... .......... .......... .......... 81% 76,0K 2s
   900K .......... .......... .......... .......... .......... 86%  101K 1s
   950K .......... .......... .......... .......... .......... 90%  180K 1s
  1000K .......... .......... .......... .......... .......... 95%  187K 0s
  1050K .......... .......... .......... .......... .......... 99%  147K 0s
  1100K                                                       100% 91,5K=10s
2018-04-05 17:43:18 (109 KB/s) - “Packages” guardado [1127063/1127063]
#6 2018-04-05 23:35
Looks like the 'Packages' file is downloadable, so we have attached a script that provides some useful debug info. Please save the script and run it in terminal:
dash dowqi18.sh --get es
and post output here.
#7 2018-04-06 06:30
Flashhh
Hello, the problem is solved!. I didnt use the script yet. I only disconnet the wire internet cable and attached a Wifi USB. Using Wifi I can download Spanish Language package!!. Dont know why using cable I cant..
Thank you for your help.
PD: I saw that the spanish translation is poor, dont know who made it but probably no one that his language of birth was spanish. If you need some help I can help with some translation.
#8 2018-04-06 07:23
Thanks, the best place to start Q4OS related translations is the Github subproject https://github.com/q4osteam/q4os-i18n . If you are not familiar with Git, we can provide the '.po' files for translations. Anyway, we recommend to use the 'poedit' application for translating.
You are also welcome to contact Trinity developers https://trinitydesktop.org/ to contribute directly to Trinity Desktop Environment project.
