#1 2018-03-27 14:51
Atmel
How to change language layer?
Hi!
I have installed q4OS with russian layout selection, in installation process I have typed username on Inglish, but  now after restart I cannt to change  keyboard language to inglish - It's typing on russian symbols.
I tried Alt+Space , Shift+Ctrl, Ctrl+Alt , Ctrl+Alt+K, Space (along) and other combinatios. I cannot to authorize!
What I can do?
Thinks!
#2 2018-03-27 21:31
Re: How to change language layer?
Unfortunately, there is no keyboard shortcut to switch to Latin character set. The only way at the moment is to perform new installation and set a Latin keyboard layout. You will be able to add a custom layout later, including Russian, as the system is installed.
Anyway, we register this issue as a serious bug, we will take a focus on that and try to fix it as soon as possible. Thanks for reporting.
#3 2018-04-11 15:15
Atmel
Thank you for your work! Q4OS is most friendly and comfortable of all.
#4 2018-04-11 15:32
The bug above is being fixed within a new live-cd revision, it will be released soon.
