Today I went to use my notebook, and I realized that I was not getting any audio out of it. Hence I tried to use the documentation instructions available at https://q4os.org/dqa011.html#install.3 , and it also did not work. Then I did the opposite that the documentation suggested - uninstalled the pavucontrol-qt and pulseaudio packages. So I ran the command "$ artsshell terminate && aplay /opt/trinity/share/sounds/KDE_Startup.wav" and the audio returned to work.
Is it okay to continue using the system without these packages? Or should I install them again?
I must admit it is unusual for sound problems to be solved this way round, normally installing Pulse solves most of the issues. However, one thing you learn very quickly with linux is that sometimes you have to think outside the box!
You may want to check that other audio stuff still works - MP3, Audio in your Browser, Video etc.
It would be of interest to have a bit more information about your machine. The best way to provide this would be for you to install a bit of software called inxi
sudo apt-get install inxithen
inxi -FUse your mouse to select all the output in Konsole, right click > Copy and then Paste the output into a response to this thread.
With Pulse installed, you can actually switch between Pulse and Alsa using the Mixer. IF Pulse is installed then the Mixer window has a drop down list on the top right. The other thing to check with Pulse is in pavucontrol make sure nothing is muted.
You should keep them installed definitely. We would recommend you to run 'pavucontrol-qt' and double check output mixer levels on the 'Output Devices' tab.
The audio was working in TDE, but when I switched to XFCE it stopped again. So I installed KMix and it returned to work again.
But I will install it again now.
Again the sound stopped. -_-
The 'Output Devices' in Pavucontrol doesn't recognize my hardware.
It only shows me this option '"Fake Output"'
System: Host: q4os Kernel: 4.9.0-6-amd64 x86_64 (64 bit) Desktop: Xfce 4.12.3
Machine: Device: laptop System: Positivo Informatica SA product: S14BW01 v: 1.06.X
Mobo: Positivo Informatica SA model: S14BW01
UEFI: American Megatrends v: 1.06.X date: 08/18/2016
Battery BAT0: charge: 39.6 Wh 92.0% condition: 43.0/42.0 Wh (102%)
CPU: Dual core Intel Celeron N3060 (-MCP-) cache: 1024 KB
clock speeds: max: 2480 MHz 1: 2479 MHz 2: 2068 MHz
Graphics: Card: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller
Resolution: 1366x768@39.97hz
GLX Renderer: Mesa DRI Intel HD Graphics 400 (Braswell)
GLX Version: 3.0 Mesa 13.0.6
Audio: Card Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio Controller
driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.9.0-6-amd64
Network: Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169
IF: ens1f1 state: down mac: 80:ee:73:d0:49:ab
Card-2: Intel Wireless 3160 driver: iwlwifi
IF: wlp3s0 state: up mac: 9c:da:3e:44:f6:2e
Drives: HDD Total Size: 500.1GB (5.7% used)
ID-1: /dev/mmcblk0 model: N/A size: 4.0GB
ID-2: /dev/sda model: ST500LM030 size: 500.1GB
Partition: ID-1: / size: 30G used: 24G (83%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 3.94GB used: 0.00GB (0%) fs: swap dev: /dev/sda4
Sensors: System Temperatures: cpu: 51.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 185 Uptime: 9 min Memory: 705.5/3746.4MB
Neither Kmix is working anymore. The system simply stops recognizing the sound card. :'(
Your posted image would suggest you have installed some KDE packages rather than their TDE equivalents, I'm not sure how much of a difference it would make if you install the kmix-trinity package instead of just kmix...
I don't know why even in TDE, the sound with Pulseaudio installed isn't working.
In TDE the Kmix even recognizes the hardware, but still no audio comes out. But now I noticed one thing: it was not to have, in that Kmix dropdown menu that is in the image, the alsamixer option?
I have not uninstalled it, and if I run alsamixer on the terminal it works. But was not he supposed to show up there, too? Is the problem in this?
I think I found where the problem is. In TDE Control Center, these are the sound devices that are appearing to me to choose.
(In my opinion) it is as if the system was sending the audio through an audio device (ALSA or OSS), and Kmix controlling the volume level of another device (PulseAudio or HD Intel PCH). The two should be defined in the same option, right?
The problem is, how do I do it?
When I was with Pulseaudio and Pavucontrol-qt uninstalled, in Kmix there was only the "Default" option in the dropdown menu.
I have noticed on my machine there are times when the only way to get sound working was to go to pavucontrol and unmute some settings there, I have re-installed since then though so cannot go back and check what they were...
You kmix image looks the same as mine and if you select the "PulseAudio" option it should show just the "Master" volume slider, make sure this is not muted and then you can return to the "HDA Intel PCH" settings to make sure nothing is muted there either and then chek your sound is working again.
If this does not get your sound working you could try re-installing pavucontrol and go through the settings there to ensure nothing is muted and that sound is being sent through to the device correctly. With pavucontrol you can see in the output tab that sound is being played (even if you cannot hear it) and you have to make sure it is being sent to the correct channel (either speakers/headphones/line out, or whatever options your machine has available.
You may need to set the correct Master channel for Kmix-trinity, so - Right-click to 'mixer' icon in system tray -> 'Select Master Channel...' -> set 'Current Mixer' to 'PulseAudio' in the top right listbox -> click 'Ok' to close the dialog.
Thereafter unmute related outputs in kmix as well as in pavucontrol-qt, check mixer levels, and reboot for sure.
We recommend to use the 'kmix-trinity' package instead of 'kmix', as already mentioned here https://www.q4os.org/forum/viewtopic.ph … 415#p12415
You need to keep the original value "Autodetect" here.
I have noticed on my machine there are times when the only way to get sound working was to go to pavucontrol and unmute some settings there ...
They should be output settings on the 'Pavucontrol' -> 'Output Devices' tab.
q4osteam,
I reinstalled PulseAudio and Pavucontrol-qt. Then I uninstalled and purged them.
After, I purged kmix (not kmix-trinity).
Then I deleted .config folder (in /home/joaopedro/.config) and rebooted. But the sound wasn't working yet. I was so tired and went sleep.
Today, after reconfiguring all my settings (because I deleted the .config...), I reinstalled kmix (not kmix-trinity) and pulseaudio. And the sound now is working. I don't know why, but it is working now. :v
