#1 2018-02-25 20:00
dbuske
install on 64 bit machine
Currently I have windows 10 32-bit on the Dell inspiron 1750.
But a 64bit cpu...
I play alot of old dos games which are easier to setup on 32-bit
I want q4os for 64-bit computing
#2 2018-02-26 04:28
Re: install on 64 bit machine
Is there a question?  I'm guessing it's can you dual boot a 64-bit q4os with a 32-bit Windows?  If so, yes you most certainly can.
#3 2018-02-26 08:51
UAOS
Yes it is weird dbuske, but true.  I am using an old dell vostro 200 the would only install win 32 bits.  It came with Windows XP 32, tried Win 7 64 bit and didn't work, but the 32 bit version of Windows 7 did work.  All my Linux are 64 bit versions that I use on my Dell Vostro 200, even now my Q4OS.
Good luck, and have fun.
A home Linux user who believes that Linux is the future.
#4 2018-02-26 14:05
dbuske
Thanks for answers.
Q4os installs but will not run.
I get error 30
What is error 30?
Thanks
#5 2018-02-28 09:18
I get error 30
What is error 30?
Please specify more detailed info and procedure to reproduce the issue.
