#1 2018-02-20 16:20
crossworx
laptop touch sensitivity
when working on my  laptop the pointer really moves around almost out of control. how can I adjust this?
#2 2018-02-20 23:22
Re: laptop touch sensitivity
Are you running Orion or Scorpion?
#3 2018-02-21 20:47
crossworx
I don't know. I am very ignorant of this operating system. I have an old Dell laptop I put it on so I can use it. Tell how to find it and I proceed.
#4 2018-02-21 21:06
Run in terminal:
$ get-q4os-version
#5 2018-02-22 00:18
crossworx
is that a space between the $ and letter "g"
#6 2018-02-22 00:37
The $ sign just denotes that it should be run as user, if it were a # it would mean to run it as root. The exact command would be
get-q4os-version
#7 2018-02-22 04:05
crossworx
got it. thanks for your patience with me.
#8 2018-02-22 10:02
You're welcome, we all had to start somewhere smile
#9 2018-02-23 20:51
crossworx
is this right  1.8.8-n3     ??
#10 2018-02-24 07:25
You're running Orion which is based on Debian Jessie 8 - which is absolutely fine.
Open Control Centre>Peripherals>Mouse>Advanced
Reduce the Pointer Acceleration to 1.5 - click apply - see if that works for you.
That may be a bit sluggish for an external mouse - depends on the hardware so you may need to experiment.
If it is totally wild when the figure is set to - say - 1,  then there's something else at play.
The best bet would be to install an information gathering utility called inxi
sudo apt-get install inxi
Then - in Konsole - run
inxi -F
Using your mouse you can then copy and paste the output into a reply and someone here can take a look and see if anything pops out.
You could install the latest kernel which has more up to date drivers that may help. If your machine is less than ~5 yrs old it may be worth a try. If your machine is older than that I'd urge caution.
The Q4OS debs have provided a simple way of doing this
sudo qinst-kernel-bpo
but I'd wait for further advice before doing so.
#11 2018-07-21 18:14
crossworx
i know it has been several months since you answered. i got so frustrated with this i just closed my laptop. after my time away i decided to try again.
i applied your answer and it worked great. my mouse behaves!! thank again.
#12 2018-07-22 05:49
smile
