Is Hdparm a part of Q4os or can it be installed? Does it work wirh q4os? I want to check harddrive speed.
Thanks die you messages in advance!
I don't use it myself, but it is available from the standard Debian repository and can be installed either using synaptic package manager or from a terminal with
sudo apt install hdparm
It should work without issue with Q4OS
Hope this helps
