Hello,
this is my first post in this forum and I hope I got the right subforum.
I have a problem with my external hard drive with two partitions. This plate is connected via USB via an HDD adapter. When switching on, there is a triple "open with" dialog.
How can I switch off this dialogue. I manually mount the partitions via Krusader. This is fine for me as I only need a partition most of the time. I hope that I have explained the problem sufficiently.
I have been using q4os for a week and am very satisfied.
Thank you.
When you see the 'open with' screen come up, typically you pick an action(open in new window) and click on the box(always do this with devices) in the lower left hand corner and then only the konqueror screen will come up in future mounts of devices. Close the screens manually if you dont need them but youll need them if you use other devices such as USB stick.
Hope I understood your issue.
I have attached a screenshot for a better understanding. A checkbox for permanent selection is missing with me. When confirming that I want to use Krusader comes this warning:
/ media / User / Backup is a folder
but a file was expected.
Sorry but I can not find a solution. I do not need the hard drive often but it's annoying.
If I use Thunar this dialog is not visible and I can manually mount the partitions. So I think that it is a problem of Krusader. Thunar is fine with me and I will take this file manager. Therefore, the problem is solved for me but the problem with Krusader remains.
I once used Kubuntu 14.04 a long time ago and I remember remembering that it was there already. If someone could suggest a solution, I would be very grateful.
Sorry for the bad screenshot. I'm not sure yet with the BB syntax.
greez
Ice - welcome
Agree with you - there are often 'conflicting' outputs - never like Krusader either - aint choice marvelous!
Often have conflict with terminal in sudo O/S's - one works, another does not ... again, its probably only
the interface that is problematic - my WD USB HDD are always problematic - the HDD's do take a while
before they are recognized/usable, which causes some programs some difficulty on boot/execution
Glad its not a HDD issue - have fun here
Regards
Jack
greez
Krusader>Settings>Advanced>Automount File Systems may be the point that is causing this.
It depends if the warning is from Krusader or KDE. You also have Desktop>Behaviour>Device Icons as a source of dialog boxes
Hello,
thanks for the answers.
I just restarted my PC and then came the right dialog box. I've selected "Do nothing." The partitions appear in Krusader's list and I can manually select them (hang in.) The setting is now permanent.
@ jackdanielsesq
ntfs partitions take a bit longer to mount. That's okay. I only use ext4. So I never really have problems.
Now I have also found the attachment box. With a coffee in hand, it works better with me.
My problem is solved for me. Thanks for your thoughts.
greez
Glad it worked out IcyBox,as Ive never seen the dialog boxes you showed in your image(used magnifying glass) and this using Krusader. Im not a big fan of Krusader as it has had some issues over time I havent experienced with apps such as Thunar.
Misttake
Hi,
I'm still trying to set ourselves up and Thunar is a good and well-known file manager. But I have Dolphin installed and it seems to be just right. Similar in appearance and appearance as Thnar.
I had also tried "spacefm-gtk3" and maybe there was something stuck. I threw everything down again and installed Dolphin with "file-roller plug-in". Everything is all right again.
Krusader is old and the operation took some getting used to, but I could have come to terms with it. Can you tell me how Krusader gets uninstalled?
sudo apt remove krusader
does not work for me.
Excuse the screenshotm. My mistake, since I'm not proficient in BBCode. Pssst: Quietly = I hate it.
I've uploaded a screenshot as an attachment. My hard drive is connected via a USB adapter and is recognized as a block device.
greez
sudo apt-get remove krusader
will do the trick.
will do the trick.
Your tip in all honor but apt and apt-get is the same except the apt-get is the old version and only minor differences exist. See the manpages for both.
I installed Synaptic and there Krusader was marked as installed and it could also be uninstalled, but the dependencies are very considerable.
Necessary changes are
ipcodecs-q4, lookswitscher, q4os-desktop, q4os-firefox, q4os-nuvola-icons, q4os-paper-icons
Krusader seems to be deeply rooted in the system and it is not recommended to remove it.
Can anyone explain to me? I thought Konqueror manages the Desktop?
greez
I noticed on my system krusader is not installed, and due to that I would say it must be removable. can you post the output of the following commands?
export LC_ALL=C
apt-get -s remove krusader
unset LC_ALL
Each line is a seperate command and you should run each one in order. This will do three things...
1. set output language to English
2. simulate the remove command
3. set language back to default for user
This will not remove Krusader but will give some advice on what would happen if you tried to remove it.
NOTE: This command does not need root privileges and will run as normal user
Hi,
yes, I can do it. Here is the output.
jag@q4os-desktop:~$ sudo export LC_ALL=C
jag@q4os-desktop:~$ sudo apt-get -s remove krusader
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
Paket »krusader« ist nicht installiert, wird also auch nicht entfernt.
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
jag@q4os-desktop:~$ sudo unset LC_ALL
My installation is with the official iso image of this download page.
I can also show Inxi:
System: Host: q4os-desktop Kernel: 4.9.0-5-686-pae i686 (32 bit) Desktop: KDE Plasma 3
Machine: Device: desktop Mobo: MSI model: G41M-P26 (MS-7592) v: 5.0 BIOS: American Megatrends v: V26.11 date: 12/10/2012
CPU: Dual core Intel Core2 Duo E6750 (-MCP-) cache: 4096 KB
clock speeds: max: 2670 MHz 1: 2336 MHz 2: 2003 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] RV570 [Radeon X1950 PRO]
Display Server: X.Org 1.19.2 drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
Resolution: 1920x1080@60.00hz
GLX Renderer: Gallium 0.4 on ATI RV570 GLX Version: 2.1 Mesa 13.0.6
Audio: Card Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.9.0-5-686-pae
Network: Card-1: Qualcomm Atheros AR8132 Fast Ethernet driver: atl1c
IF: enp3s0 state: down mac: 8c:89:a5:89:f9:64
Card-2: Netgear WPN111 RangeMax Wireless USB 2.0 Adapter driver: ar5523
IF: wlx00184dd93e8f state: N/A mac: N/A
Drives: HDD Total Size: 1160.2GB (13.4% used)
ID-1: /dev/sda model: SAMSUNG_HD161GJ size: 160.0GB
ID-2: /dev/sdb model: TOSHIBA_DT01ACA1 size: 1000.2GB
Partition: ID-1: / size: 124G used: 5.0G (5%) fs: ext4 dev: /dev/sdb4
ID-2: swap-1 size: 4.29GB used: 0.00GB (0%) fs: swap dev: /dev/sdb5
Sensors: System Temperatures: cpu: 45.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 147 Uptime: 11 min Memory: 701.7/4042.7MB Client: Shell (bash) inxi: 2.3.5
and
jag@q4os-desktop:~$ uname -a
Linux q4os-desktop 4.9.0-5-686-pae #1 SMP Debian 4.9.65-3+deb9u2 (2018-01-04) i686 GNU/Linux
So I notice in Synaptic Krusader to uninstall. Then a window with necessary changes appears. There are the above mentioned packages listed. With the hint that the action also has effects. In the removal list are then listed the packages I have mentioned above.
I'm surprised that's why I wanted to ask m, al. It's like an open-heart surgery on the system.
greez
I just checked and the package is krusader-trinity and it is integrated into the Q4OS desktop, and as such cannot be removed. You can of course use any other file manager without having to remove this one.
And just for reference I did put in my previous post to run those commands as user and as you used sudo it was run as root user so the first and last commands were ineffective and I could not understand your output but have assumed it says something like program not installed...
"Fertig
Paket »krusader« ist nicht installiert, wird also auch nicht entfernt."
google translate
"Finished
Dependency tree is set up.
Status information is read .... Done
The krusader package is not installed, so it will not be removed."
Dolphin is what I use most of the time and is included with the main distro i use for my everyday work. I did not uninstall Krusader though with Q4OS.
Thanks for the effort. I leave everything as it is and keep using Dolphin. However, that is already a trap for a rude user of maybe just time to uninstall krusader clicks in Synaptic.
But I still stay with the q4os desktop even though I'm a bit limited there.
greez
