#1 2018-02-03 06:27
ragilsatrio
Touchpad config in Control Panel
A Nice feature already on other DE is :
1. Two finger click
2. Three finger click
3. Two finger scrolling
please add an option in control panel to configure it .
thanks
*delete this post if it was duplicate , but redirect me to that previous post
#2 2018-02-04 01:42
Re: Touchpad config in Control Panel
Which DE has this feature as i havent seen it so far?
#3 2018-02-04 10:25
You can always set the touchpad to your preference in /etc/X11/xorg.conf.d/50-synaptics.conf (if you have synaptics installed) or /etc/X11/xorg.conf.d/60-libinput.conf (if you are using libinput (which is default for Scorpion)). There is a post here with some information that might help.
#4 2018-02-04 18:33
Just playing with LXLE Ubuntu based - used to use it all the time - it has a configuration for trackpad that does exactly as suggested by OP
#5 2018-02-04 18:35
Hes looking for something a bit more straightforward and GUi based.  Ive seen something with an LXDE distro that comes close to what hes referring to.
#6 2018-02-05 05:27
Plasma 5/Gnome both have very good gui's for this.  If I'm not mistaken, XFCE uses the Gnome one as well.
#7 2018-02-05 23:46
What are the apps in KDE 5 tlmiller?  It may be because I havent run a KDE distro on my laptops and didnt notice.  I do run XFCE though and dont remember seeing one.
#8 2018-02-06 07:17
Doesn't come much simpler...........LXLE (LXDE plus bits of others) - my pad doesn't support this stuff AFAIK and I don't use it anyway - thought it may help - probably requires Synaptics driver and may not integrate with TDE directly
