#1 2016-01-14 13:38
Automounting usb stick
Hi all, I have got a SD card which I use in a camera, I have set it to mount automatically in properties=>Mounting and assigned it a mount point of /media/(user)/CamCard but it always mounts to /media/(user)/(UUID)
Any Ideas as to why it doesn't use the path specified?
I have not created the folder in /media/(user) maybe this needs to be done first, but as it is an option to specify the mount path I thought it would create it if required...
Creating the directory for the mount didn't alter the mounting directory...
Dai
#2 2016-01-14 21:56
Re: Automounting usb stick
We can confirm, this is reproducible Trinity bug, please report it at TDE bugtracker http://bugs.trinitydesktop.org
#3 2016-01-14 22:58
Bug reported here
I am not 100% sure which version of trinity I am using, I entered R14.1.0 on the bug report but can edit if I am wrong, please advise.
Dai
#4 2016-01-15 07:49
Thank you for reporting. Q4OS 1.4 Orion uses TDE 14.0.1
#5 2016-01-15 09:51
Thank you, bug report edited to reflect true TDE version
Dai
#6 2016-01-20 16:18
Ok, Update on this issue
Slávek Banko  wrote:
I found that with udisks / udisks2 is no way to use a user-defined mount
points. It seems that we have no chance to solve it for udisks / udisks2.
So looks like It aint gonna get fixed... sad
Dai
