hello everybody,
i am using Q4OS 2.4 32-bit, with XPQ4 theme changer.
everytime i click on a folder or file icon in PCManFM file manager, the file manager crashes.
this always happens when i set the view to "Detailed List", but no problem when the view is set to "Icon View".
so i think the issue is with the "Detailed List" view of PCManFM file manager.
i am wondering, is there any solution to this bug ?
thanks before.
The issue you describe with pcmanfm appears to be happening in many distros of all types so you might want to contact the devs of pcmanfm to see if there is a fix. Its not directed related to Q4OS or XPQ4 from what Ive read so far.
noted that. thank you for the insights, sir.
