#1 2017-10-09 14:23
fasn
Scropion: m3u8 type file problem
just using Scorpion of Q4os
and download  .m3u8 file,  right click it choose what app to open and remmber it, after that. double click another .m3u8  , it still using kwrite open it but not VLC
what should i do with it?
#2 2017-10-11 08:29
Re: Scropion: m3u8 type file problem
We will check the issue in the next few hours and post a feedback as soon as possible.
#3 2017-10-11 09:28
You need to sort 'vlc' as the preferred application for opening '.m3u8' files. Right click on the '.m3u8' file in file manager -> Properties -> click 'Edit file type' icon -> move VLC to the first position in the 'Application preference order'. Now, VLC will open any '.m3u8' file on double click.
#4 2018-01-26 03:34
Nanmun
Well, did you try this way?
Step 1: Open VLC media player and select “Open Network Stream” under Media table.
Step 2: Paste M3U8 video URL into the network URL box, and then select “Convert” in the lower right.
Step 3: A new window will pop up after clicking Convert. Select MP4 as output video format and then set the output folder path.
Step 4: After all settings are done, you can click “Start” to convert M3U8 file to MP4. The output MP4 video will be found in the destination file.
