#1 2016-01-14 13:48
Programs disappeared
I have noticed the Programs have vanished from the main menu, I did notice before that it had moved to above the separator line and now it has gone completely. I haven't changed anything with the menu so I'm pretty confident it's nothing I have done this time smile
All suggestions welcome
Dai
#2 2016-01-14 13:52
Re: Programs disappeared
Just rebooted and it came back, but not the first time it has happened... Not sure why it happened or steps needed to reproduce, will post again if i find a connection.
Dai
#3 2016-01-14 14:08
Yes, it happens rarely on some specifically configured systems. The workaround, that should fix it, is to re-switch from classic - kicker - classic menu.
You could report a bug http://sourceforge.net/p/q4os/tickets , and add some description if you will find any connections. Thank you.
#4 2016-01-14 14:57
Thanks Q4os team, I will file a report if I manage to reproduce it.
Dai
