#1 2017-12-24 23:06
Cannot install mythtv-frontend
I need to install mythtv-frontend to manage my mythtv pvr but it will not install due to q4os-desktop requiring fonts-droid which would be removed to make way for fonts-droid-fallback which is required for mythtv-frontend, is there any workaround to this? (that doesn't involve compiling myth from scratch)
#2 2017-12-25 00:51
Re: Cannot install mythtv-frontend
This isnt what you were hoping for but look at this,
www.mythtv.org/wiki/Installing_MythTV_on_Debian
and this,
https://packages.debian.org/search?keywords=fonts-droid
Checked my Q4OS install and fonts-droid is installed by default and fonts-droid fallback is available for install, is there another issue beyond availability of these packages?
#3 2017-12-25 07:13
It would seem to me that making fonts a dependency in any application is just plain wrong. Indeed you cannot install fonts-droid-fallback without getting messed up dependency issues. Tried with --no-install-recommends and it still gets gnarly.
Given this could be a genuine mistake when the Q4 packages were built perhaps the team could rebuild the packages which have fonts-droid as dependencies and make them recommend instead?? I think the debs with font dependencies are all meta-packages.
On mine right now they are ipcodecs-q4 q4os-desktop q4os-wine-layer synaptic-q4 but I suspect a whole raft more may be involved.
P.S. I don't like Droid - never have, never will smile
#4 2017-12-25 09:10
@CC
Thanks, I have seen those links already, but Q4OS has droids font as required for the q4os-desktop package and so would be removed and I do not want to have to compile my own packages (but may be forced to later...) and the actual problem is the q4os-desktop package would be removed when installing fonts-droid-fallback which is obviously going to cause problems.
@bin
I can kind of understand when fonts are made a dependency to keep the applications looking correct but I think it is a problem when it prevents another font (or the same but updated one) from being installed... I don't think it would have been a "mistake" by the devs as I would imagine it would have been done for the same reasons as I just stated, but I do need a workaround as I rely on mythtv and it is much easier to use the frontend rather than using mythweb (web frontend for use in any browser) and there are some things that I cannot do (or not as easily) without the full frontend...
It does seem like Q4OS has fonts-droid embedded in many of its packages, and considering this package is not available for Stretch I would hope that fonts-droid-fallback could be substituted at some stage. Given that this would be quite a large undertaking I do not expect it would be available too soon, but I do live in hope. smile
#5 2017-12-25 18:32
Gotcha, I didnt realize the depth of the problem as Im not familiar with MythTV(know of it) and the issues youre discussing.
#6 2017-12-25 19:18
We can confirm this issue, unfortunately there is no workaround at the moment. We will fix this asap and will keep a feedback here.
#7 2017-12-25 23:11
Thanks guys. smile
#8 2017-12-26 12:15
The 'fonts-droid-fallback' package from Debian repositories replaces 'fonts-droid' package, so they cannot be installed alongside each other. Since 'fonts-droid' is required by the q4os-desktop, it's not possible to fix this issue easily. It will be properly fixed in the next major Q4OS version based on Debian Buster.
Nonetheless, we have attached a special version of 'q4os-desktop' package to workaround the problem in Q4OS Scorpion. The file attached upgrades the current q4os-desktop package and permits installation of 'fonts-droid-fallback'. It must be installed manually using 'dpkg -i' command:
$ sudo dpkg -i q4os-desktop_2.4.1-n2-fixdroid_all.deb
and could be followed by:
$ sudo apt-get install fonts-droid-fallback
Keep in mind, the command above will also remove 'fonts-droid' package.
#9 2017-12-26 12:19
Thank you guys, I really didn't expect such a quick solution, I hope I didn't interrupt your festivities too much. I will post back here with results. smile
#10 2017-12-26 18:15
Its your Christmas present Dai, smile
#11 2017-12-27 00:33
@CC
And a good one too!
@Q4OS Team
Thank you very much indeed, everything seems to be working correctly and I haven't noticed any anything different or any side effects (so far) so it looks like a great solution for me.
Just one question though, will I need to re-install the q4os-desktop package if there is an update in the future or will you be rolling this out to the main distribution?
#12 2017-12-27 00:56
No, in case of an update of the q4os-desktop package, your system should hold the package, and possible dependencies, in the current version. You will need to ask for an updated package and install it manually, using 'dpkg -i'. Fortunately, the q4os-desktop package is not supposed to be updated frequently and the occasional updates shouldn't bring significant changes.
#13 2017-12-27 11:01
Ok, thank you, I will keep an eye open for updates. smile
#14 2018-02-18 21:05
Hi guys, I noticed there has been an update to q4os-desktop, would you be able to provide an update to the fixdroid patch for me please? I'm not in a rush as the package is held and causing no issues so whenever you have spare time it would be great. smile
#15 2018-02-19 08:16
Here you are smile
#16 2018-02-19 09:27
That's awesome, thanks guys smile
#17 2018-03-18 11:17
There is new 'q4os-desktop' update, version 2.4.6-n1, available in repositories, that fixes the 'fonts-droid' dependency in a proper system way. So the workaround above is not needed anymore, just update your system.
#18 2018-03-18 11:27
That's great news, Thank you guys. smile
