#1 2017-12-24 04:48
fasn
makefile problem
i'm using .install.sh file when i install softether vpn client , i got the error afther some "agreement'
/usr/bin/ld: lib/libz.a(zutil.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(inflate.o): relocation R_X86_64_32 against symbol `zcalloc' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(inftrees.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(inffast.o): relocation R_X86_64_32S against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libz.a(crc32.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: lib/libintelaes.a(intel_aes.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: 最后的链结失败: 输出不可表示的节
collect2: error: ld returned 1 exit status
Makefile:18: recipe for target 'i_read_and_agree_the_license_agreement' failed
make: *** [i_read_and_agree_the_license_agreement] Error 1
k@shab:~/vpnclient$ relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
#2 2017-12-24 05:21
jackdanielsesq
Re: makefile problem
最后的链结失败: 输出不可表示的节 - truncated
Regards
Jack
#3 2017-12-24 11:38
@fasn
Please specify more exactly, where do you download the install script from and how do you proceed the install process ?
#4 2017-12-24 12:53
fasn
@fasn
there
http://www.softether-download.com/files … bit.tar.gz
i download and tar xvf it. then i cd to the dir and then i run bash .install.sh
