#1 2017-12-05 12:48
moheganer2
Storage
I am new to Q40S (5days)-love it so far.I used the windows installer. Is there anyway to increase the storage area at this point?
#2 2017-12-05 13:12
Re: Storage
There is no dedicated gui tool to resize the drive available at the moment, so an ordinary user will need to proceed a new clean installation with another storage size. Anyway, you can change the size of the rootfs loopback file from a live media and then run the 'resize2fs' utility on it. It just works, but you need to know what you are doing.
#3 2017-12-05 14:04
moheganer2
Re: Storage
Thanks for the help.    great work on your part.
