#1 2017-11-14 18:49
rafaelramos
Mirror ftp.br.debian.org does not always connect
Good afternoon,
I'm doing tests with Scorpion 2.4 version.
One of the first things I do is edit the "sources.list" file and add the ftp.br.debian.org mirror, because the default address (ftp.debian.org) is too slow for my location.
sudo kwrite /etc/apt/sources.list
Include -> deb http://ftp.br.debian.org/debian/ jessie main contrib non-free
sudo apt-get update
But it happens that when I install Full Profile, or some other application via apt-get, packages are rarely downloaded by "ftp.br.debian.org", but by the default address "ftp.debian.org", and the installations they take too long for me!
Is there any way to bypass the default address and just force "ftp.br.debian.org"?
#2 2017-11-14 19:09
Re: Mirror ftp.br.debian.org does not always connect
You would need to edit /etc/apt/sources.list.d/20_debian.list but there is a warning from the devs not to edit this CRITICAL system file, but so long as you make the changes correctly it should be ok. Some future update might re-write this file though, but that would need confirmation from the devs.
#3 2017-11-21 22:16
rafaelramos
@q4osteam,
Is there a problem editing this file?
#4 2017-11-21 22:53
If you exactly know what you are doing, no.
#5 2017-11-22 14:41
rafaelramos
In case I just want to add the ".br", change a line:
deb http://ftp.debian.org/debian/ stretch main contrib non-free
For:
deb http://ftp.br.debian.org/debian/ stretch main contrib non-free
#6 2017-11-22 14:58
Yes, depending on the mirror status, it should be ok.
