#1 2017-11-09 23:54
clive
LAN Settings - Connection to internet fails
I have set my network addresses the same as for Windows (using the parallel boot option of Q4OS). Connection to internet fails. Is there a step I, as a Q4OS noob, may have missed?
Thank you
#2 2017-11-10 02:40
Re: LAN Settings - Connection to internet fails
Do you not have a DHCP server on your network to allow you just to get an automatic configuration from?  This is, IMO, the easiest way.
Are you running Orion or Scorpion?
#3 2017-11-10 03:12
clive
I'm on a network where settings must be done manually. Running Scorpion
Thank you
#4 2017-11-10 04:53
Can you post the output of the command 'ip add' from the terminal here?
#5 2017-11-10 08:04
You could also configure your ip properties using 'nmtui' tool from terminal:
$ nmtui
The NetworkManager text user interface tool, 'nmtui', provides a user interface to configure networking by controlling NetworkManager.
#6 2017-11-12 22:20
clive
@tlmiller76
command not found
@Q4OS Team
Ran nmtui. Able to check settings set using GUI. Confirmed that they are the settings used on this machine when running Windows. When attempting to run Desktop Profiler the error code is 30.
Thank you
