#1 2017-11-09 19:30
pdf
System freezes
Hi,
I would love to try this distro on an old netbook, but every time I try to install,
the system locks up - I mostly get as far as the keyboard layout.
Mint was working fine prior to this.
Netbook is an Asus Eee, with 2 gigs of Ram.
Any help would be appreciated!
Thanks, Phil.
#2 2017-11-09 21:01
Re: System freezes
Did you try Scorpion 2.4 or Orion 1.8.8?  Orion would be a better choice for your system.
#3 2017-11-09 21:19
Re: System freezes
We would recommend you to install from the 'Installation CD', see 2nd section of the download site http://www.q4os.org/downloads1.html
#4 2017-11-09 23:25
pdf
Re: System freezes
Thanks for the suggestions.
P.
#5 2017-11-10 00:02
Re: System freezes
Which version of Mint were you using? 18.2? What DE?
