#1 2016-01-06 17:28
bobby
What packages and steps needed to develop .esh install
Would some one please provide a list of packages they recommend to be installed to help  me and others so we can learn to create Q4OS installers = *.esh ?e
I would like to start with Q4OS installers before learning how to compile *.deb packages from the source files.
Thanks so much for your time.
Bobby
No Longer Using Q4OS
#2 2016-01-06 17:40
Re: What packages and steps needed to develop .esh install
You are welcome to create Q4OS applications installers, it's not too difficult job. Installers could be integrated in Software Centre or to be used standalone, just downloaded and ran by doubleclick.
We recommend you to install and use our 'Development Pack' http://www.q4os.org/developer.html , you can find simple example how to start to create app installers in the documentation http://www.q4os.org/dqa009.html
#3 2016-01-06 18:03
bobby
Installed & now reading docs.  seems more complicated to me so I will dive in and work through it.
Thanks,
Bobby
#4 2016-01-06 18:43
You are welcome to ask here.
